Hardwood Over Hardwood?
Hey guys me and a buddy of mine were talkin about wether or not you could put 3/4" hardwood over 3/4" hardwood? So heres the question could you put hardwood over hardwood going the same direction? I would probly tear the old up I wouldnt think the nails would go in very well. what you guys think?
Thanks ,Dave |
"da Whale don't hesitate"
Trade: Hard Surface Flooring
Re: Hardwood Over Hardwood?
Um...NO! To much movement. Naildown hardwood is not that hard to takeup. My thoughts would be, why would you risk the investment to save a little bit of labor.
Precision Flooring (772) 237-9900 Tile, Hardwood, Laminate, and Resilient Installation, Sales & Repair - "We do it right the FIRST time" |
Trade: Flooring contractor
Some manufacturers say its ok, as long as the new floor is layed on a right angle to the old floor.
I didnt think it could be done either, a buddy of mine wants to do it at his house, Like I said if it was me id tear the old up.
Thanks , Dave |
What is the ultimate reason for new hardwood??? You can carefully remove the old hardwood, pull the nails, and the reinstall it using modern flooring cleats. I have done that several times.
I admit...I don't know everything...but don't tell my kids I told you.
Flooring? What's that?
Trade: Flooring
I have to agree with donedat. Why not spend the time to remove the existing hardwood and nails. Then reinstall it properly with a flooring Nailer. If the finish or wood requires it, refinish. It will save you money in the long run.
#7 | |
Re: Hardwood Over Hardwood?Quote:
That's how I do it, - - successfully . . .
http://www.tr-built.com |
Trade: Exterior Construction
Re: Hardwood Over Hardwood? |
#9 | |
Trade: Flooring Contractor
If it's a nailed down hardwood floor over an existing subfloor, no, I tear it out. Can you imagine the height difference if you just kept adding layers of hardwood? |
#10 | |
That's when you $ell 'em a new kitchen, too!! . . .
| Help Installing Hardwood over old/new Concrete Slab | Hages | Flooring | 7 | 06-04-2008 01:02 PM |
| Hardwood or tile in Spec House Kitchens | williefb | Kitchens & Baths | 18 | 02-19-2008 05:37 PM |
| Hardwood Flooring - First Go at It | DecksEtc | Flooring | 56 | 10-05-2006 01:41 PM |
| Hardwood Floors over Radiant Heat | bigtick | Flooring | 10 | 12-08-2005 03:43 PM |
| Questionss on Hardwood underlayment and expansion | newtofloor | Flooring | 8 | 11-24-2005 08:18 PM |
