Hardwood Nailed To Ply Glued To Slab. MASTIC TYPE?
Old 10-26-2006, 02:31 PM   #1
brianosaur's Avatar
Trade: hardwood flooring
If I install a nailed solid floor over a slab, I will install it upon a 3/4" ply subfloor. I will adhere the ply to the slab using KARNACK Wood Block Mastic and Remington powder shot nails. The mastic comes in 5 gal cans and looks like black roofing tar. I will 1/4" knotch trowel it to the entire slab surface. Its about $45 a can.
My distributor is out of it and when I called Karnak the told me the next closest retailer is about 1 1/2 to 2 hrs away. Trying to eliminate a four hour ride and wasting half a day, does anyone use any other brand that I can look into?
Thanks
brianosaur is offline
Old 10-26-2006, 03:33 PM   #2
Master Craftsman
Big Dave's Avatar
Trade: Rustic interior woodwork
Re: Hardwood Nailed To Ply Glued To Slab. MASTIC TYPE?
Bostik.
http://www.bostik-us.com/about/index...ssReleaseId=48
Do one thing at a time, do it well, then move on.
http://www.bigdaveswoodworks.com
Big Dave is offline
Help Installing Hardwood over old/new Concrete Slab Hages Flooring 7 06-04-2008 01:02 PM
built up slab question stampcrete Concrete & Paving 9 03-27-2008 05:24 PM
Type of Paper Under Hardwood CharlieDaw Flooring 2 04-12-2007 10:43 PM
Demo a foundation under a radiant heat slab without disturbing the slab...? wackman Remodeling 18 04-02-2007 12:38 AM
Hardwood over hardwood? dkillianjr Flooring 9 09-21-2006 09:07 AM
