Hardwood Floors Over Radiant Heat
Old 11-30-2005, 10:10 AM   #1
bigtick's Avatar
Can anyone share their experience with me of installing 3/4" solid hardwood floors over a staple-up radiant heat system.
Radiant heat contractors claim that you can install solid hardwood over the heat because the new systems operate at lower tempratures. Hardwood manufacturers (most of them) say not to.
What else could you use for flooring in a high end house? I can't tile the whole thing.
Thanks.
bigtick is offline
Old 11-30-2005, 12:33 PM   #2
Flooring Guru
Floorwizard's Avatar
Trade: Sales Manager
Re: Hardwood Floors Over Radiant Heat
I would wonder how the wood can be nailed into an in floor heating system.
I would buy an engineered wood and float it over the top.
Let's not forget that the heat will dry it out, so humidity will be key.
50% sounds about right.
Floorwizard is offline
Old 11-30-2005, 03:08 PM   #3
Donedat's Avatar
Trade: Hardwood Flooring
Send a message via MSN to Donedat
If the tubes are attached to the underside of the subfloor, you can install hardwood flooring. Use Quarter Sawn flooring and use shorter nails. The longest 45 degree nail should be 1 3/4". I have used 1 1/2" on systems like that. Vertical nails should be no longer than 1 1/2" nails for your starting and ending rows...a spot of construction adhesive on these rows will help hold them in place.
This is not for the homeowner diyer though. A mess can be made of this real quick.
I admit...I don't know everything...but don't tell my kids I told you.
Donedat is offline
Old 11-30-2005, 06:34 PM   #4
Marco's Avatar
Location: The Oak Floors of Marco Los Gatos, CA 408-353-4882
Lots of harwood gets installed over radiant. Search google. The Canadians do plenty. Id use a more stable wood such as oak and stay away from maple and the exotics. Quarter-sawn is a good choice. A thinner milling would help too. A floating engineered is another, easier option.
If you are worried about nails, lay more plywood and use shorter nails. A typical tube-in-concrete system get a 2 layers of 1/2" ply floated with harwood nailed.
Marco is offline
Old 11-30-2005, 09:16 PM   #5
kneel_eh!'s Avatar
Trade: Floor covering Mechanic
Send a message via Yahoo to kneel_eh!
Your right Marco, we do install a lot of h.w. over radiant up here.The important points have been noted already.
Unless you can see it, you gotta err on the side of caution and assume that the heat is right against the underside of the subfloor.
Do a test with a piece of subfloor and a couple of boards. That will tell you what length of staple to use. You certainly don't want to puncture a line.
Starter rows are glued down with an approved adhesive, angle tacked with a 11/4 brad nail on the tounge and weighted overnight. No top nailing required. Humidity is set appropriate. Never had any problems doing it this way.
Had a couple where I was able to access the heat tubes and lower them down and then go nuts!
'Just cuz I'm paranoid, does'nt mean everyone's not out to get me !!!
kneel_eh! is offline
Old 12-01-2005, 10:55 AM   #6
bigtick's Avatar
Thank you for the replys. Can any of you recommend a specific (solid floor preferably, or and engineered floor that looks solid, ie 1 strip) manufacturer of prefinished that you have used in the past and have faired well over radiant?
bigtick is offline
Old 12-01-2005, 11:22 AM   #7
Donedat's Avatar
Some products are regional so what state are you in?
Donedat is offline
Old 12-01-2005, 11:24 AM   #8
Donedat's Avatar
Kids, don't try this at home. Only for seasoned professionals. And if you do, make sure you put them back or the homeowner might freeze to death.
Donedat is offline
Old 12-01-2005, 01:14 PM   #9
Flooring Guru
If you want a good engineered that looks like real wood strips, then visit
www.mannington.com
for wider strips visit
www.kahrs.com
Old 12-01-2005, 01:32 PM   #10
bigtick's Avatar
I will check out Mannington and Kahr.
I live in PA.
Thanks again for the quick responses.
bigtick is offline
Old 12-08-2005, 03:43 PM   #11
StonewoodSP's Avatar
Trade: Hardwood Flooring, Landscape Stone, Specialty Lumber
Go with a quartersawn or edgegrain. I just worked on a project with a customer and we got them Edgegrain First Grade Canadian Maple and it will not only be very stable for him, but it has a great look to it.
StonewoodSP is offline
Radiant Floors using floor joists and reflective barriar Jacey Flooring 1 07-06-2007 01:04 PM
3/4" White Oak Hardwood over Radiant Heat WiseGuySite.com Flooring 4 04-14-2007 04:58 PM
Demo a foundation under a radiant heat slab without disturbing the slab...? wackman Remodeling 18 04-02-2007 12:38 AM
Hardwood Over Radiant Heat Dave Buskirk Flooring 5 01-03-2007 09:11 PM
Heat Exchanger Inspection Methods MechAcc HVAC 3 04-14-2005 04:38 PM
