Hardwood Flooring Install, Little Help.
Old 02-16-2008, 11:41 AM   #1
One Stop Home Improvement
spartiatis's Avatar
Trade: Builder/Remodeler
Question
Hello, we will be installing engineering hardwood flooring for one of our clients this coming up week and in the past we have always done the installation perpendicular to the joists. I was just wondering is that what everyone else does? There is sub-flooring already installed so I'm just trying to see the experts opinions on this matter. It is only our 3rd installation of hardwood.
Thanks!
spartiatis is offline
Old 02-16-2008, 02:15 PM   #2
"da Whale don't hesitate"
PrecisionFloors's Avatar
Trade: Hard Surface Flooring
Re: Hardwood Flooring Install, Little Help.
What is the subfloor assembly? Rule of thumb is perpendicular to joists, but there are some instances where it doesn't matter. Need more info.
Precision Flooring
(772) 237-9900
PrecisionFloors is offline
Old 02-16-2008, 08:21 PM   #3
spartiatis's Avatar
The hardwood will be installed on the second floor of the home within the Master Bedroom and the house was built in the Mid 70's. The subfloor is 1/2 inch plywood nailed in. The size of the room is about 14' Wide and 17' in Length. Hopefully this helps but if it doesn't let me know what else I can expand on and I will try my best.
Thank you
Old 02-16-2008, 08:33 PM   #4
If that truly is a 1/2" subfloor (which I doubt....it would be a trampoline) you need another layer of 3/4 on it first. Laid perpendicular to the first, then you can install the hardwood any direction the home owner prefers. What is this 1/2" material? Plywood, or PB?
Precision Flooring
(772) 237-9900
Old 02-17-2008, 12:18 AM   #5
Knowledge Factory
Floordude's Avatar
Never seen T&G 1/2" subfloor??
Sounds like you need more beef in the substrate.
http://www.AustinFloorguy.com
Floordude is offline
NEED GUIDANCE help on Hardwood Flooring womanangler Flooring 2 09-14-2007 01:22 PM
Hardwood install cost??? NCDeere Flooring 3 05-09-2007 04:46 PM
Hardwood Flooring - First Go at It DecksEtc Flooring 56 10-05-2006 01:41 PM
Hardwood Flooring For Large Projects StonewoodSP Marketing & Sales 1 12-08-2005 09:38 PM
How to Install Solid Hardwood Flooring on Concrete Foundation gilamherst Flooring 13 02-05-2005 07:02 PM
