Hardwood Floor Repair
Old 03-20-2006, 03:41 PM   #1
Nutty's Avatar
Trade: Small Home Improvements
A client of mine has a nasty stain about 20 inches in diameter that encompasses about 10 widths of hardwood floor. Anywho, I have done an internet search for this topic and have become familiar with it. However, does anyone have any advice as to what ehy have experienced?
I understand that the bottom of the groove will need to be removed so that the piece is able to fit the tongue. Here's the big Q......When gluing say the final piece in, is it best to glue it right to the subfloor...or should I just glue the "groove"? I am worried about expansion/contraction and eventual floor buckling if I glue right to the subfloor. Should I be concerned? I was going to use liquid nails as the glue. I am going to try and NOT face nail. Is this a good idea as well?
Thanks in advance.
Nutty is offline
Old 03-20-2006, 06:43 PM   #2
Flooring North Cackalacky
drunkrussian's Avatar
Trade: Hardwood floors, everything about them
Re: Hardwood Floor Repair
I glue to the groove and tounge, and to the subfloor. Have not had any major problems doing it this way. Also, I have found 5 min epoxy works best, that way I can sand the day I make the repair.
drunkrussian is offline
Old 03-20-2006, 10:20 PM   #3
adams,b's Avatar
Trade: hardwood floors
make sure the sub floor is dry, I put felt back in place and glue the t& g and face nail minimal.
adams,b is offline
Old 04-04-2006, 01:24 AM   #4
trialbyfire's Avatar
Trade: shingler
I have a major groan from a gluing to the floor. Just do the tongue and groove, and let it move. I won't go anywhere big, and if it has to move it is not fighting the sub.
trialbyfire is offline
Old 04-04-2006, 02:24 AM   #5
Flooring Guru
Floorwizard's Avatar
Trade: Sales Manager
What wood is it?
thickness?
engineered?
Floorwizard is offline
Old 04-05-2006, 11:49 AM   #6
Donedat's Avatar
Trade: Hardwood Flooring
Send a message via MSN to Donedat
I've use epoxy and Tightbond II Carpenters glue. I use the carpenter's glue for prefinished flooring and actually like it over epoxy. Longer cure time but more user friendly cause it's water clean-up.
I admit...I don't know everything...but don't tell my kids I told you.
Donedat is offline
Help Installing Hardwood over old/new Concrete Slab Hages Flooring 7 06-04-2008 01:02 PM
Hardwood or tile in Spec House Kitchens williefb Kitchens & Baths 18 02-19-2008 05:37 PM
Hardwood Flooring - First Go at It DecksEtc Flooring 56 10-05-2006 01:41 PM
Hardwood over hardwood? dkillianjr Flooring 9 09-21-2006 09:07 AM
Questionss on Hardwood underlayment and expansion newtofloor Flooring 8 11-24-2005 08:18 PM
