#21 |
Re: Hardwood Floor Pattern And End Joints
Understood. Pics of flooring can be difficult to take, a lot of light bouncing around.
The cust. is happy, you are happy, everything's good.
#22 |
Lol I was just commenting on the fact you took the door trim off.
Just bustin on ya, the job looks great. |
#23 |
Since you are a remodeler, you probably own several routers already, so invest in a decent set of T & G router bits, the two bit set, not the ones you have to keep resetting. Put them in a couple of routers , mill all the pieces as you make them, and eliminate the possibility of a faux paux.... much easier than a repair job.
#24 |
Splines are a PITA. Corner biscuits are most effective on small boards (6" or less), they will tie 4 corners together. Pre-fit, use glue or epoxy and go like H.
#25 | |
Trade: Remodels
Re: Hardwood Floor Pattern And End JointsQuote:
![]() I took of all the trim because it was beat to hell and it looked anything than Oriental in style. I showed her some weave stuff I saw at Lowes and she loved it for the casing and used a rather plain five inch angle edge for the base. Finished up today. Glad to be done, too! Last edited by 4yanx; 07-29-2007 at 01:33 AM. |
#26 |
When you cut all those pieces that were the same size, did you do them all at once or did you go on a row by row bases
