Home Improvement Guy
Trade: Renovations contractor
Hardwood Floor Nailer
I've been using a Bostitch floor nailer with 2" cleats for about a year now (rookie) and I''m quite happy with the results. Some people say a floor nailer using staples is better. What do you guys think?
Trade: Floors and more
Re: Hardwood Floor Nailer
I've used both, never had a callback on floor coming loose with either. Though I still hear some say that nailers hold better than staplers.
Trade: hardwood floors
We have been using 1 1/2" staples for years. Works great.
Adam,
Your kidding right. 1 1/2" staples? Haven't you ever heard of 2" staples for general nail down flooring. You want some to come through the bottom side of the subfloor for maximum strength. Shorter nails are for radiant floor heating and other plumbing clearance problems. Cleats hold better than staples, but only slightly.
I admit...I don't know everything...but don't tell my kids I told you.
well if you have 3/4" plywood and 3/4" floor, that explains why we use 11/2" staples. How could you say cleats hold better than staples. we use 2" on some occasions but usually just 11/2" staples. Never had a problem. We had problems with our nailers when we used 2" staples because they would hit the concrete and screw up the driver.
#6 | |
Re: Hardwood Floor NailerQuote:
But, I have also gone in a added flooring to existing stapled down floors...had to lace in some...staples really hold well. Pretty hard to get the boards up when they are stapled.
Trade: Carpet, wood, Vinyl , tile ..
I was at the NOFMA School a few years ago ,and they said the cleats hold a little better .. But they split more tounges .. for what its worth ..
#8 | |
#9 | |
#10 | |
Try a test. Face-nail a 3/4" boad down to the subfloor with a 1 1/2 in. 15g brad. Do the same to another board with a longer brad. Then try to pull ead board up. Notice how much easier the shorter nail pulls out?
"da Whale don't hesitate"
Trade: Hard Surface Flooring
I prefer staples myself. Faster, leaves head sticking up alot less often, and staples are cheaper per sf also. I use a Bostich M3FS, 2inch fastener.
Trade: General
To date, my only relatively big jobs have been putting down engineered planks or parquets, stapled or glued depending on subfloor. I've used a couple of the smallish Bostitch staplers with decent results. I've done smaller jobs of 3/4" (single room, foyer, etc), and used a manual Porta-Nailer brand. That'll give you a workout :]
In a couple of weeks, I'll be laying 2000 sq ft of 3/4" prefinished oak. I ordered a PrimaTech P240 along with their shoe for prefinished planks. I'll be using L-cleats for this job. I'll report back on how I like the nailer. Anyone here use a PrimaTech? -Jimi |
I didn't like the primatech because the hose plugs in on the right side and hits the wall when you're nailing at the end of a room. This was a rather old unit, maybe the newer ones have moved the hose. Just something to look for in a floor nailer.
Trade: Flooring contractor
Most of the bamboo's I have installed lately, will only warranty their product if you use cleats, and not staples.
Trade: shingler
I have moved away from hardwoods and into engineered. Much easier!
Flooring Guru
Trade: Sales Manager
I assume you mean moving from solid to engineered huh?
yea, makes it easier. easy money for some brands.
------------------------ "in 20 years you will regret more what you did not do than what you did" |
I had an opportunity to buy a new Bostitch manual floor nailer for cheap, but decided against it. Too many guys have told me that you gotta hit it just right and hard enough or the nail will go in half way. Then it's a bugger to get out and you can't hammer it in. Have any of you guys used one?
#18 |
Ron, don't waste your cash unless it is to use as a backup to a pneumatic gun. You can pickup the Bostich or any of the knockoffs on evilBay for around 3 bills.
Precision Flooring (772) 237-9900 Tile, Hardwood, Laminate, and Resilient Installation, Sales & Repair - "We do it right the FIRST time" |
#19 |
Trade: Trim/Finish Carpentry, Woodworking, if its wood we do it!
I remember the Bostitch floor staplers that had the trigger button for areas up against walls where you couldnt hit it with the hammer. Too bad the one my father had for years was stolen out of our trailer!
#20 | |
As far as 2 inch staples grabbing the joist, that is a specious claim at best. The most one could hope for is about a quarter inch of penetration(and on a 45 degree angle at that). I can pull that out with my teeth. Bottom line is this, no amount of fastener left dangling in the crawlspace adds any stability to the assembly. This is not my opinion. No serious scholars in these matters disagree with these simple facts. Call the NWFA or NOFMA and see what they say. Always here to help, Chuck. p.s. I like using 2 in staples just because of how they feel when I haul ass with a nailer. 1-1/2 in staples don't give that heavy feel when you cycle the tool. That is a very selfish reason to use them, though. |
| Help Installing Hardwood over old/new Concrete Slab | Hages | Flooring | 7 | 06-04-2008 01:02 PM |
| Hardwood or tile in Spec House Kitchens | williefb | Kitchens & Baths | 18 | 02-19-2008 05:37 PM |
| Hardwood Flooring - First Go at It | DecksEtc | Flooring | 56 | 10-05-2006 01:41 PM |
| Hardwood over hardwood? | dkillianjr | Flooring | 9 | 09-21-2006 09:07 AM |
| Questionss on Hardwood underlayment and expansion | newtofloor | Flooring | 8 | 11-24-2005 08:18 PM |
