Hardwood Floor Inlay
Old 02-18-2009, 07:42 PM   #1
Platinum8's Avatar
Trade: Finish carpentry and Painting
Question
Hey fellas,
I am about to start a hardwood floor job and they want to do maple floors with a cherry inlay. I am using prefinished floors, 3 1/4" wide boards. I wanted some of your opinions. Should I picture frame around the room with the maple or should I just run it in one direction even on the short ends? I think I want to picture frame it and if so how many times should I go around before the inlay? I was thinking about 3 wraps.
Also how do you guys start? Do you start with outer picture frame or should i start in the middle with all the boards running in one direction and screw some strappin to floor where my inlay is going?
Thanks in advance!!
Platinum8 is offline
Old 02-18-2009, 08:39 PM   #2
jamestrd's Avatar
Trade: wood flooring
Re: Hardwood Floor Inlay
as Bob Ross used to say "it's your world"
if you do a border, then start with the field first..measure out where you border will start and lay just beyond this point.
you can use a dummy board as a guide where your border will start....
insert cherry inlay( I assume you mean feature strip) where you want in placed in the border. then you can zip the other side
since pre finished,
apply tape to where you will be cutting and use a quality cross cutting blade.(prevents splintering of finish)..router in a groove and install slip toungue.
then start your border.
border size is subjective, but should fit to the size of the room..
always a preference..
jamestrd is offline
Old 02-18-2009, 09:04 PM   #3
s. donato's Avatar
i did a cherry with maple inlay ;-)
http://picasaweb.google.com/saldonat...83341639653362
i make sure i lay the flooring square to the most noticeable feature of the room. i usually snap reference lines all over the place. i use my 4 point laser to square out the room. good luck i can't wait to see the pics of it.
BSA Renovations - Restoration and Renovation Specialists serving New Jersey's Bergen County.
Bergen County's Premier Home Maintenance Provider.
s. donato is offline
Old 02-19-2009, 07:04 AM   #4
egotistical prick
Cdat's Avatar
Trade: Wood Inlay
I'd picture frame it but it depends on the size of the room, don't it? As stated above, lay out the cherry to go over the places of the inlay, then cut the inlay and tongue/groove the ends and install.
Cdat is offline
Old 02-19-2009, 02:39 PM   #5
"da Whale don't hesitate"
PrecisionFloors's Avatar
Trade: Hard Surface Flooring
I prefer to snap lines and lay the field first. Then I use my Festool saw and guide rails to get nice smooth, square, and chip- free edges. Depending on the thickness of the material and the substrate I will then route a groove around all sides, make some tongues on the table saw real quick, and install the border.
Precision Flooring
(772) 237-9900
PrecisionFloors is offline
The Following User Says Thank You to PrecisionFloors For This Useful Post:
Metro M & L (01-07-2010)
Old 02-19-2009, 03:20 PM   #6
Knowledge Factory
Floordude's Avatar
Originally Posted by Platinum8 View Post
Hey fellas,
Thanks in advance!!
All options you should get discussed and documented which pick, how far and where, then signed off on, before you take it upon yourself to chose these specifics of the job.
http://www.AustinFloorguy.com
Floordude is offline
The Following User Says Thank You to Floordude For This Useful Post:
Old 02-19-2009, 06:22 PM   #7
Professional Remodeler
firemike's Avatar
all options you should get discussed and documented which pick, how far and where, then signed off on, before you take it upon yourself to chose these specifics of the job.
bingo!
-Mike-
Falcon Contracting
Residential - Commercial
firemike is offline
Old 02-19-2009, 09:07 PM   #8
Platinum8's Avatar
should i miter the corners of my feature strip and the 3 or so rows that picture frame it or should I but them? Or is that all just personal pref?
thanks
Old 02-19-2009, 10:06 PM   #9
jcalvin's Avatar
i done a herringbone border using 5 boards white oak then 3 boards walnut and turned the white oak inside that traditionally in my personal home. it was the first piece of hardwood i had ever put down before in my life. i had always hired it done but didn't want to pay it when the money came out of my own pocket. it was absolutely beautiful. the way the wood came together with the different grains and colors, i loved it. the only advice i can give on the installation is to take it one board at a time and make darn sure you stay straight. it is VERY tedious, time consuming, and trying. take your time it is well worth it. as far as pricing a job like this, hourly only! make sure the ho knows there is no way of pricing something like this unless you only do floors like this everyday.
Cal
You hired WHO
jcalvin is offline
The Following User Says Thank You to jcalvin For This Useful Post:
Platinum8 (02-20-2009)
Old 02-20-2009, 08:47 AM   #10
s. donato's Avatar
i would not miter the corners. utilize the T&Gs as much as possible. like jcalvin said just alternate sides of the the picture frame. they will weave together nicely and it will be a strong finish unlike miters.
The Following User Says Thank You to s. donato For This Useful Post:
Old 02-20-2009, 12:47 PM   #11
the big 12 inch's Avatar
Trade: hardwood floor contractor 28 yrs.
thanks
Only pu**sys log cabin their corners!!!
the big 12 inch is offline
Old 02-20-2009, 11:37 PM   #12
Um..I can still have a tongue & groove with a miter....that's what a router is for
Precision Flooring
(772) 237-9900
Old 01-07-2010, 05:38 PM   #13
Tile inlay guy
Floor Inlay's Avatar
Trade: Tile and Floor Inlay Installation
Well that's good to know before I start
www.medallionsplus.com
Floor Inlay is offline
Old 01-07-2010, 06:04 PM   #14
pinwheel's Avatar
I must be a p*ssy, huh?
Here's a floor I laid last spring. It was 4" red oak with a walnut border. I started at the wall & worked my way in. I've demoed some period floors laid like this in the past & they were all started at the wall working their way to the middle.
pinwheel is offline
Old 01-07-2010, 07:18 PM   #15
I like Green things
WarnerConstInc.'s Avatar
Here, here to Festool and flooring work.
Originally Posted by Leo G View Post
Thanks for that tidbit of information Darcy.
Warner Remodeling ll Auburn Indiana Remodeling ll Dekalb County Remodeling ll Custom Woodworking Auburn Indiana
Warner Remodeling Facebook
WarnerConstInc. is online now
Old 01-07-2010, 09:54 PM   #16
Tile inlay guy
Looks good to me Did you install a medallion?
Old 01-07-2010, 10:20 PM   #17
pinwheel's Avatar
Thank you. No, not in that floor, but I have installed medallions on other jobs, just don't have any pics handy.
pinwheel is offline
Old 01-08-2010, 02:43 AM   #18
72chevy4x4's Avatar
Pinwheel-do you have any finished pics of that floor? I would be interested in seeing better details where the two rooms come together.
72chevy4x4 is offline
Old 01-09-2010, 06:47 PM   #19
KG007's Avatar
Trade: Flooring & cabinetry
If you haven't already bought your wood, and you are doing it yourself, have you considered buying some actual borders and corner blocks?
Personally, I'd miter the corners if I wan't using corner blocks.
Means mitering the rows OUTSIDE the picture frame, too. (Assuming you are running the outside rows in both directions.
If your room isn't really square I might consider changing baseboard and using 3/4 x 3/4 quarter round to give myself some leeway, especially if you start from anything other than the wall. Look forward to pics.
KG007 is offline
Old 01-25-2010, 10:31 AM   #20
Hardwood contractor
msv's Avatar
Trade: Flooring
Cherry floors with maple borders, 5"wide each... unfortunately, it was unfinished, site-sanded....
50% down, 50% after all your complaints
MSV, www.getyourfloors.com, Atlanta Hardwood Flooring Blog
M.S.C on Twitter, M.S.C on YouTube
msv is offline
The Following 2 Users Say Thank You to msv For This Useful Post:
pinwheel (01-25-2010), Winchester (01-25-2010)
3/4 T&G Hardwood floor underlayment options jdghandyman Flooring 16 09-03-2009 01:57 PM
Hardwood over Asbestos Tile 4yanx Flooring 10 11-08-2008 08:39 PM
How to edge Carpet at radius abutting Hardwood caswensk Flooring 2 10-12-2008 11:14 PM
Re-using Hardwood J-Peffer Flooring 7 09-28-2008 01:50 AM
Hardwood over hardwood? dkillianjr Flooring 9 09-21-2006 09:07 AM
