Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Flooring
Old 09-14-2009, 08:01 AM   #1
dvd
Trade: contractor
Hardwood floor direction
I have a hardwood floor to laydown on approximatly 1800sf. This is new construction but the floor joist layout on one section of the house is running parrell with the hardwood. I was always taught to run floring perpendicular to the floor joist. Will it matter to run flooring in the section of floor joist that will run same direction as hardwood? Thanks for any help.
dvd is offline   Reply With Quote
Old 09-14-2009, 08:37 AM   #2
ChrWright's Avatar
Trade: Builder/Remodeler
Sure you're a contractor?
It's not a good idea unless you reinforce with another layer of plywood over the subfloor.
Christopher Wright, WrightWorks, LLC
www.WrightWorks.net - Facebook - Christopher Wright, Remodeling Info on Twitter
Indianapolis Remodeling Contractor - Remodeling Photos: Kitchens, Baths, Room Additions, Basements
"Everything has been said before, but since nobody listens we have to keep going back and beginning all over again." --Andre Gide
ChrWright is offline   Reply With Quote
Old 09-14-2009, 06:30 PM   #3
the big 12 inch's Avatar
Trade: hardwood floor contractor 28 yrs.
As long as you have 3/4 or better t&g plywood you can lay it either way...Iv'e never had a problem in 28 yrs...
the big 12 inch is offline   Reply With Quote
The Following User Says Thank You to the big 12 inch For This Useful Post:
Metro M & L (09-17-2009)
Old 09-15-2009, 02:16 AM   #4
dvd
Trade: contractor
thanks for your reply big I do appreciate it.
Old 09-15-2009, 02:34 PM   #5
Knowledge Factory
Floordude's Avatar
You can also block the underside every 16" -24"
I wouldn't go over a single layer of ¾", I have always been shown, at least 7/8 single layer, or double ½".
http://www.AustinFloorguy.com
Floordude is offline   Reply With Quote
Old 09-15-2009, 02:40 PM   #6
Knowledge Factory
Floordude's Avatar
Double click
Old 09-15-2009, 03:29 PM   #7
Trade: Remodeling general
how about turning the floor in that section
naptown CR is offline   Reply With Quote
Old 09-15-2009, 09:01 PM   #8
Flooring Guru
Floorwizard's Avatar
Trade: Sales Manager
hmm...nobody has asked what type of wood...
if it's engineered... and you float it...then there is no difference.
Floorwizard is offline   Reply With Quote
Old 09-17-2009, 10:28 PM   #9
Trade: Flooring & Remodeling
Floating a floor is great with light traffic , but at entry ways & halls it falls apart with 2 years .
Titebond II is great , but it can't handle the traffic with a full household with kids . If the underlayment padding is thick like the quietwalk , it will fall apart.
finaltouchfloor is offline   Reply With Quote
Old 09-18-2009, 09:34 PM   #10
Flooring Guru
what? that makes no sense....
both are durable, both are valuable, both can't take water on the seams for long periods, both will dent, both will scratch.
one uses more wood than the other....that's about it.
do you have any logical information that proves that theory.....?
Old 09-19-2009, 01:51 AM   #11
We either naildown hardwood floors to a plywood sub-floor or glue-down to a slab. My competitors try to cut corners and just float engineered floors but they fall apart in high traffic areas.
When the floor flexes with the under-layment padding over time the glue applied to the tongue & groove fails.
Unless there's a locking system like a laminate there will be problems . Also the floor always sounds hollow; a nail-down installation or glue-down solves all problems.
Old 09-19-2009, 07:26 AM   #12
Trade: Flooring
Send a message via Yahoo to Mike Costello
Your painting with a broad stroke here.
I have been installing floating engineered for many years now, in both commercial and residential areas and have never had one come apart.
Just like anything else, when done correctly it will last.
Engineered has its applications where solid hardwoods cant go, so to say you would never use an engineered or a floating floor either means your missing out on work or using solid where it shouldnt go.
Mike Costello is offline   Reply With Quote
Old 09-19-2009, 10:31 AM   #13
Flooring Guru
There are plenty of woods with locking systems with no glue.
but I still disagree.
Anderson makes a hell of a nice wood with tounge and groove...it's engineered and it has worked great.
I would think in 13 years, I would agree with you if that statement was true.
that is correct.
that's like me saying Solid wood is crap because it has more movement than engineered.
but that's why we use billions of cleats right?
both woods are fine.
Old 09-21-2009, 01:12 PM   #14
Trade: Construction
What is your business again? I wouldn't say flooring expert.
Angdeer is offline   Reply With Quote
Hardwood help mhillc Flooring 8 08-27-2009 04:00 PM
5 Best Hardwood Floor Tips And Save Money Too! Benoakley Flooring 6 08-17-2009 12:49 PM
Sanding and Finishing Engineered Hardwood AcademyHardwood Flooring 3 08-06-2009 02:38 PM
hardwood floor and door jambs woodworkbykirk Finish Carpentry 28 03-01-2009 06:54 PM
Hardwood over Asbestos Tile 4yanx Flooring 10 11-08-2008 08:39 PM
