Hardwood Floor On Concrete Basement?
Old 07-06-2006, 07:21 PM   #1
georgia dawg's Avatar
Trade: general contractor - SFR
An installer told me that he can put a hardwood floor on a concrete basement by 1) putting a layer of 6 mil poly, 2) laying flat down 1x or 2x sleepers 12" o.c. and around perimeter, 3) then laying floor.
He also told me the concrete needs to have cured for at least 60 days before doing this.
Will this work?
georgia dawg is offline
Old 07-07-2006, 10:08 PM   #2
Donedat's Avatar
Trade: Hardwood Flooring
Send a message via MSN to Donedat
Re: Hardwood Floor On Concrete Basement?
Solid hardwood flooring should never be installed below grade...sleepers or not. At the very minimum you could be trapping mold and mildew under the plastic. Hardwood will out last your home if you install it right the first time.
I admit...I don't know everything...but don't tell my kids I told you.
Donedat is offline
Old 07-07-2006, 10:49 PM   #3
Flooring Guru
Floorwizard's Avatar
Trade: Sales Manager
It's easier to buy an engineered wood and float it.
Floorwizard is offline
Old 07-09-2006, 07:32 PM   #4
Flooring North Cackalacky
drunkrussian's Avatar
Trade: Hardwood floors, everything about them
A floating subfloor or stringer system is accepable. NWFA does have guidelines for this, and many people have done this succesfully. The big thing is making sure the concrete has an acceptable mositure level. I also have sealed the concrete in the past and then have used the 6 mil plastic.
Most people stay away from this because of 2 reasons. They hear 3/4 unfinsished shold not be put below grade, and it will not last, or they find out how much the price is and decide to go with something cheeper.
drunkrussian is offline
Old 07-09-2006, 11:17 PM   #5
Teetorbilt's Avatar
If you want to go for it, seal the concrete with at least 2 coats and pray for the best.
Another option is to go to solid wood and just accept the 'tavern floor'. A little uneven but has worked for hundreds of years.
Albert Einstein
Teetorbilt is offline
Old 07-13-2006, 12:14 PM   #6
ramblemn's Avatar
Trade: woodworker
Delta-FL on the floor, laminate padding and the laminate.
Delta-Fl is a blast to work with, and is water and vapor proof.
ramblemn is offline
Help Installing Hardwood over old/new Concrete Slab Hages Flooring 7 06-04-2008 01:02 PM
Would Concrete stair be good going to basement from garage? TurnkeyConst Masonry 1 04-04-2007 09:47 AM
HELP! Basement floor disaster Profiter Construction 5 07-11-2006 09:01 PM
Basement floor dilemma ron schenker Flooring 11 07-02-2006 09:36 PM
installing basement windows in concrete blocks mtpgoat Remodeling 2 03-25-2006 10:06 AM
