Trade: Design/Build
Hardwood Cupping
Recently delivered 2 cartons of 5" pre-finished red oak "cabin grade" hardwood to a job site to allow acclimation. Only 2 cartons because we were planning on replacing some boards that had been damaged as a result of cupping. All indications were that the original floor was not properly acclimated prior to installation. I'm aware of what normally causes cupping and although we disputed the proper acclimation finding, we couldn't prove otherwise. The house is infrequently occupied, air heat and cooling, timber frame with insulated panel exterior. Super tight home, HRV set to run intermittently and vent the baths.
The bands were removed from the carton and the boxes cut open. 2 weeks later I returned to take moisture readings and discovered every board cupped, throughout the box. Moisture read 8-10%, as did all the other wood in the house. Returning the wood to a super dry environment has all but eliminated the cup, still is slight. Less than 6% moisture content, lowest reading on my meter. RH in the house is elevated, but not extreme, 50-60%. Original floor remains cupped, but acceptable to the Owner, thankfully with the exception of a few boards. Basically, unless I dry the house to what I would consider an unhealthy level, I am unable to acclimate this wood. Anyone have any thoughts on this? I'm beginning to question the reasoning for the initial cupping. Could the wood be too dry before the finish was applied? Thanks in advance. |
Knowledge Factory
Re: Hardwood Cupping
What was the MC of the subfloor?
Were the cartons sitting on the subfloor? Sounds like the crawl space/cellar is really damp.
#3 | |
Trade: Design/Build
Re: Hardwood CuppingQuote:
I'm going to bring in another sample of similar but different manufacturer and see what happens. Have you ever seen hardwood cup prior to installation? Thanks again. |
LRG WoodCrafting
It's wood. It can do anything it pleases. If it becomes unbalanced within it will change shape. It is possible that it came form the factory over dried less than 6% and bringing it back to normal home conditions has caused it to change shape.
Trade: hardwood floor contractor 28 yrs.
Lots of variables at play here..If you have cupping on 2 above grade levels and the cupping is everywhere,this is in part probably due to the house being vacant at times and there is a source of moist air from the basement.Is the basement HVAC operating full time?Is there a dehumidifier in the basement?Houses that are not occupied full time can hold more humidity due to lack of air movement, and most people do not set the temps at the same comfort levels as the would if they lived there full time...Seen this many many times over the years...
#6 | |
Trade: Design/Build
Also at play is an HRV that runs with bath exhausts, and intermittently. I'm suspecting in the summer months it brings in quite a bit of moist air. |
Trade: Flooring
I've installed a lot of unfinished flooring in every extreme. Houses under construction in the winter where humidity levels were very high, and I've never seen flooring start cupping before it's installed. There has to be something going on with the environment that it's in. There is a moisture problem somewhere. There must be some piece of information that you're not getting.
solar guy
Trade: solar contracting
You answered your own question.
When you brought the wood in it was at a low MC Since it was prefinished it only picked up moisture on the unfinished side causing it to cup. When dried out it straightened up. Try applying a finish to the back and edges and re aclimate it. It should pick up moisture more evenly and the cupping should be eliminated or at least less severe. |
| The Following User Says Thank You to naptown CR For This Useful Post: | msv (12-05-2009) |
#9 | |
Knowledge Factory
It is called "greenhousing" Pretty common with rentals and snowbirds.
Going back to Leo, wood does what it does. Cupping means that the moisture content is higher underneath. Was a vapor barrier installed?
just a question, but isn't cupping going to move the wood in the direction of the growth rings regardless which side of the flooring has the higher MC?
#12 | |
Knowledge Factory
Vessels/cells of all wood are hygroscopic. As they absorb moisture, they swell. The bottom of the board with higher moisture content, swells more than the top, which has less moisture content.
| hardwood floor and door jambs | woodworkbykirk | Finish Carpentry | 33 | 12-05-2009 09:26 AM |
| Hardwood help | mhillc | Flooring | 8 | 08-27-2009 05:00 PM |
| 5 Best Hardwood Floor Tips And Save Money Too! | Benoakley | Flooring | 6 | 08-17-2009 01:49 PM |
| Sanding and Finishing Engineered Hardwood | AcademyHardwood | Flooring | 3 | 08-06-2009 03:38 PM |
| Hardwood over Asbestos Tile | 4yanx | Flooring | 10 | 11-08-2008 08:39 PM |
