Hardwood Chatter
Old 05-21-2009, 07:57 PM   #1
rabbit26's Avatar
Trade: hardwood floor sanding
Hardwood Chatter
what is the best way of dealing with the chatter problem? tiny ripples left from the belt and drum sanders?
rabbit26 is offline
Old 05-21-2009, 09:23 PM   #2
Casap CEO
mrwoodman's Avatar
Trade: Contractor Membership Service
Re: Hardwood Chatter
Are you doing this yourself with a large rental sander? Or did the contractor leave this behind? is the floor still raw?
Ron T
mrwoodman is offline
Old 05-22-2009, 07:44 AM   #3
the big 12 inch's Avatar
Trade: hardwood floor contractor 28 yrs.
If this is happening on multiple machines I would say it is probably the man standing behind it scenario...Take then to a good repair shop and have them serviced..$$$$$..
the big 12 inch is offline
Old 05-22-2009, 09:21 AM   #4
jamestrd's Avatar
Trade: wood flooring
Depends on the type of machine..
if it is a typical drum sander,
bearings, belts, and wheels, as well the drum itself must be in proper working order.. keeping the machine clean and free of excessive dust build is important.
a belt sander will chatter under similar circumstances, but most often when you see chatter, there is something stuck in the drum, like a staple..
in a drum sander, its the break in the paper that also effects to cut of the machine.
jamestrd is offline
Old 05-22-2009, 11:55 AM   #5
Feedin the geese
Joining_heads's Avatar
Trade: Finish Carpenter
Check the tension of the drive belt and the sander. Our floor guy will disengage the machine, turn it on, and adjust the tension until no vibrations or coarse noises can be heard.
This might sound weird in words but makes sense in person.
The machine we use is a Lagler-hummel
Joining_heads is offline
Old 05-22-2009, 07:25 PM   #6
Casap CEO
mrwoodman's Avatar
The Drum may also need re-balanced or re-covered. As Joining_heads mentioned, try the tension adjustments and also make sure your paper is on the drum tight or try slowing down your pace.
I also use a 12" belt Lagler-hummel. Sweet Machine!
Ron T
Old 05-22-2009, 08:41 PM   #7
egotistical prick
Cdat's Avatar
Trade: Wood Inlay
Ya' get what ya' pay for...
Cdat is offline
Old 05-22-2009, 09:13 PM   #8
rabbit26's Avatar
i just bought an almost new bona belt sander and it leaves a tiny amount of chatter. i am gonna try the tensioning device. if i can find it. it didn't have it owners manual. floors are still extremely beautiful, just finished 2400 sqft of 5" plak red oak. just seaking perfection. any more advice will be appreciated. thanks
rabbit26 is offline
hardwood floor and door jambs woodworkbykirk Finish Carpentry 33 12-05-2009 09:26 AM
Hardwood Flooring Underlayment Jonny85 Flooring 2 04-21-2009 06:36 PM
Installing Hardwood. tips and what to look for....in a finishing contractor? J-Peffer Flooring 3 03-24-2009 09:58 AM
Hardwood over Asbestos Tile 4yanx Flooring 10 11-08-2008 08:39 PM
Hardwood over hardwood? dkillianjr Flooring 9 09-21-2006 09:07 AM
