Hardwood To Berber Transition?
Old 01-09-2006, 08:36 PM   #1
project manager
badassdak20's Avatar
hey guys my first post and it regards, what is the best trim piece to use to transition from 3/4 hardwood to berber carpet? I've seen reducer and threshold that seem to be the ticket but which is best? the floor only has a tongue on one of three sides.any suggestions are much appreciated considering the cost of prefinished trim pieces. by the way i just installed this floor so there was nothing to reference.Doug
badassdak20 is offline
Old 01-10-2006, 01:05 PM   #2
Flooring Guru
Floorwizard's Avatar
Trade: Sales Manager
Re: Hardwood To Berber Transition?
End cap or baby threshold works fine.
some installers will cut the wood flush, and then turn and tuck the carpet to the wood without a molding.
Floorwizard is offline
Old 01-10-2006, 08:09 PM   #3
adams,b's Avatar
Trade: hardwood floors
We usually miter down a board so it will reduce down to about 3/8" and then the carpet can be tucked tight against it.
adams,b is offline
Old 01-11-2006, 04:58 AM   #4
King of karpets's Avatar
Trade: Carpet, wood, Vinyl , tile ..
depends on thickness of pad & berber .. we just cut the tongue off , put tackless in front of the wood , and treat it like a wall .. we use a 100 oz berbermate pad .. 1/4 inch thick .. and power streach it .. rebond pads tend to break down under berber ,and dont hold the streach has well .. Good Luck ..
King of karpets is offline
Old 01-11-2006, 02:04 PM   #5
Flooring Guru
Yuk....I cringe when I see rebond under Berber.
I agree with you completley
Old 01-30-2006, 02:09 AM   #6
woodfloors's Avatar
Trade: wood flooring
butt the wood to the carpet looks better than anything else. i have been doing this for a long time now. cleaner look.
hope this helps!
woodfloors is offline
Hardwood or tile in Spec House Kitchens williefb Kitchens & Baths 18 02-19-2008 05:37 PM
Hardwood Flooring - First Go at It DecksEtc Flooring 56 10-05-2006 01:41 PM
Hardwood over hardwood? dkillianjr Flooring 9 09-21-2006 09:07 AM
Hardwood Floors over Radiant Heat bigtick Flooring 10 12-08-2005 03:43 PM
Questionss on Hardwood underlayment and expansion newtofloor Flooring 8 11-24-2005 08:18 PM
