Hardibacker Vs Easyboard (foam Based)
Old 07-26-2008, 12:30 AM   #1
Nick1123's Avatar
I always use hardibacker. Im sure everyone has now come across these new foam based backer boards (there are a few brands out there). I was wondering if anyone uses them and some thoughts on them?? They are def way lighter and can be cut with a utility knife. Extremely easy to install!! My only hesitation is quality and whats will happen in the long run.. Thoughts???
Nick1123 is offline
Old 07-26-2008, 10:28 AM   #2
Rewards Points: 2,000
Re: Hardibacker Vs Easyboard (foam Based)
Like most new stuff, I'll stick with
what I know already works.
Let someone else find out what's
wrong with the new stuff and learn
from their pain.
neolitic is offline
Old 07-27-2008, 10:17 PM   #3
Nick1123's Avatar
that is usually the way i go.. but this is so easy i just cant resist
Nick1123 is offline
Old 07-30-2008, 07:20 AM   #4
tile contractor
Bill_Vincent's Avatar
Trade: Ceramic and stone tile contractor
Well then give it a shot!! As for me, my area Custom rep gave me a 50 foot roll of EasyMAT to try about a year ago. I gave it away.
"Whether you think you can, or you think you can't, you're probably right."
http://www.creativeceramicandmarble.com
Bill_Vincent is offline
Old 07-31-2008, 03:21 AM   #5
Nick1123's Avatar
are you talking about the easy mat that is about an 1/8 inch thick??? why would u screw the poor guy by giving him that??
Nick1123 is offline
Old 07-31-2008, 07:05 AM   #6
tile contractor
He was gonna go to Dal and BUY it, so I gave mine to him!
Old 08-04-2008, 08:13 PM   #7
Nick1123's Avatar
I would try the MAT stuff if i could here just a few good things about it... but everyone who has ever used it doesnt trust it... so i guess i dont either
Nick1123 is offline
Old 08-05-2008, 08:42 AM   #8
Psychologist/Remodeler
Ted Striker's Avatar
Trade: General Contractor / Remodeling
I have a friend in Cleveland who has been a ceramic installer for 10 years, he called me about a month ago to tell me about this product.
He will never go back to cement or hardie. The cost is more but the time in labor is a huge saving.
Not to mention using the same utility blade for the entire install
Ted Striker is offline
Old 08-19-2008, 05:07 PM   #9
novicepro's Avatar
Trade: general contracting
Rewards Points: 75
I was curious about this stuff so I thought I'd try it on a small bathroom remodel I did. I'ts really easy to work with cause it cuts easy and it's light. But that's about it. I usually float the tiles in the shower area (except glass tiles) to make it plumb. The only problem that I had was whenever I pushed on the tiles I was setting, the wall moved cause it's flimsy foam. When the mud dried (i had about 1/2" to 3/4 of mud behind the tiles) it was solid- no movement. I don't think I'll use this stuff again because I don't really trust it. If anyone wanted to use it though I would not recomend troweling the tiles on it. I think the thicker the mud the stronger your walls are with this product.
novicepro is offline
Old 08-21-2008, 07:23 PM   #10
loganm's Avatar
Trade: HVAC/Carpentry
I personally dont even like the hardibacker...thinks its crap to be quite honest.
Ive always used durok/wonderboard and ill keep on with that.
loganm is offline
Old 08-21-2008, 07:49 PM   #11
tile contractor
It's not crap, but it IS tough to work with. Either way, I'm with you-- I'll stick with Durock.
Old 08-21-2008, 08:06 PM   #12
General Contractor
Snow Man's Avatar
Trade: Construction Management
True wet bed or Hardi for us
DECOSnowRemoval&IceControl
Serving Delaware County & Philadelphia Pa
610 457-9721
Snow Man is offline
Old 09-06-2008, 07:40 PM   #13
zkt's Avatar
Trade: historical house restoration and preservation
Durock for tile wetbed for mosiacs
zkt is offline
Old 09-07-2008, 05:59 PM   #14
tiledepot's Avatar
Trade: General and flooring contractor B, C15, ASB
If you referring to the Ez Backer board, I assure you it is not “flimsy foam” for wall it recommend the ½” thick and for floor use the ¼”, the great benefit and saving is when it come to area need to be waterproof, as the material itself is water resistance you only need to waterproof the joint of each board.
tiledepot is offline
Old 09-07-2008, 09:38 PM   #15
Mellison's Avatar
Trade: Home Improvement General Contractor
As easy as shears make using hardibacker IMHO it is a no brainer. Hardibacker every time.
Mellison is offline
Old 09-10-2008, 02:38 PM   #16
Thunder Tile's Avatar
Trade: tile contractor
"As easy as shears make using hardibacker IMHO it is a no brainer. Hardibacker every time. " Mellison
Mellison-Please educate me on these shears... I typically score with a utility knife or use a 7" skill saw.
Thunder Tile is offline
Old 09-10-2008, 04:16 PM   #17
KMac's Avatar
Trade: Finish Carpenter
Rewards Points: 150
I'm a finish carpenter and worked on a job with a GC that was doing a bath remodel. I worked with this guy on alot of jobs and he has done many many bathrooms and decided to try the EZ board on this one. A week after the tile guy did his thing there were problems with the floor. Wound up having to demo and redo the whole thing. He's back to hardi now. It was very easy to handle and install though!
KMac is offline
Old 09-10-2008, 05:01 PM   #18
Remodeling GC
kevjob's Avatar
Rewards Points: 2
try a google search for hardybacker shears, make sure they can cut 1/2 inch boards. no dust and very easy.
Kevin
www.ObrienConstructionDenver.com
kevjob is offline
Foam Board vs. OSB JimmyZimmier Framing 17 11-06-2010 04:54 PM
Spray foam question NCDeere Insulation 16 01-22-2010 11:15 AM
Spray Foam Damage - HELP! crawfobc Insulation 4 07-04-2008 09:07 PM
hardibacker over linoleum A.W.Davis Flooring 6 10-22-2006 02:19 AM
Isulating with Foam for Roofs? FrankJr Construction 2 03-25-2006 09:05 PM
