'Gymnasium' Finish - Flooring - Contractor Talk
'Gymnasium' Finish
Old 09-28-2011, 10:19 PM   #1
TopFloor's Avatar
Trade: Floorist
Rewards Points: 154
'Gymnasium' Finish
I was contacted by a customer who already sanded and stained their floor. They only want me to apply the finish.
I inspected the floor, showed them the (suprisingly few) drum marks, etc. and the floor looks ready to finish. They used a miniwax stain and have purchased enough water-base Varathane for two coats. Here are the issues I would like your input on:
1. The customer has big dogs. They talked to an 'old-timer' who said he would always use some type of 'gymnasium additive' in the final coat, presumably a urethane/ acrylic hardener. My guess is they will need to switch to something other than Varathane (e.g dura seal x-terra) if they want something 'high-traffic'. UPDATE: They decided to go with Bona Mega. Any thoughts?
2. How about simply applying a third coat?
3. Any concerns about water-based over Minwax stain? Most of the stain has been drying a few days, but time-constraints might have me working in a hallway stained less than a day before. UPDATE: I will be in there a little more than 1 day after stain is applied. With temperatures recently ranging 70-83, humidity 55%, think that will fly?
Thanks in advance for the thoughtful replies.
Last edited by TopFloor; 09-29-2011 at 02:06 AM. Reason: some details have changed
TopFloor is offline
Old 09-28-2011, 10:42 PM   #2
Old school Ranger
floorinstall's Avatar
Trade: flooring
Rewards Points: 152
Re: 'Gymnasium' Finish
DO NOT USE VERATHANE!!!!!!!!!!! Duraseal makes an oil modified gym floor finish or use A canalized (2part) water borne finish. If you use the waterborne make sure the oil stain is completely dry. I doubt the hallway will be sufficiently dry in such a short period of time.
floorinstall is offline
The Following User Says Thank You to floorinstall For This Useful Post:
TopFloor (09-28-2011)
Old 09-29-2011, 12:49 AM   #3
Orlando Car
Floormasta78's Avatar
Trade: certified floor covering installer.
Rewards Points: 1,154
They are obviously looking for a pro finish.. A good friend of mine said , if they pay for it , who cares about the rest . Even if they want me to work in a pink tutu... Do it , don't worry , get your money..
http://www.facebook.com/#!/certifiedfloorcovering
Certified Floor Covering
Serving All California
( 510 ) 760 - 6810
Floormasta78 is offline
The Following User Says Thank You to Floormasta78 For This Useful Post:
TopFloor (09-29-2011)
Old 09-29-2011, 09:29 AM   #4
astor's Avatar
Trade: FI
Rewards Points: 704
I suggest using Bona Traffic or Basic Coating StreetShoe. Bona Mega is not non-yellowing+ not strong as these.
You need to wait at least 3 days before applying water base over oil based stains.depends on the humidity levels etc. Double check and be sure the stain is completely dry before, otherwise finish will move the stain.
You should be very clear that whatever under the finish is not your problem,stain patches etc.
astor is offline
The Following User Says Thank You to astor For This Useful Post:
Old 09-29-2011, 10:32 PM   #5
Particulate Filter
Metro M & L's Avatar
Trade: Flooring
Rewards Points: 1,356
How do you verify the stain is dry Astor?
Metro M & L is offline
Old 09-30-2011, 05:42 AM   #6
General Contractor
greg24k's Avatar
Rewards Points: 7,516
I did a floor refinishing job for someone, they had a racquetball court inside theirs house, and I spoke with a few guys who do gym floor refinishing for schools, etc and they recommended to use Dura Seal Gymthane 450 Finish... this stuff is designed for gym floors and resists marks or scuffing.
greg24k is offline
TopFloor (10-02-2011)
Old 09-30-2011, 04:51 PM   #7
nymasterfloors's Avatar
Trade: Flooring
Rewards Points: 150
Hey metro a few ways to see is stain is dry 1. Take a rag and wipe the floor with it if stain comes onto rag it's not dry. 2. Feel the wood it has a sort of moist feeling when still wet 3. Moisture reader you have to know the moisture content of the wood prior to application of the stain4. Always do a test area in a non conspicuous spot I.e. Closet
Money is evil Family is life Love conquers all
nymasterfloors is offline
The Following 2 Users Say Thank You to nymasterfloors For This Useful Post:
Metro M & L (10-01-2011), TopFloor (10-02-2011)
Old 09-30-2011, 05:42 PM   #8
Particulate Filter
Trade: Flooring
Seems like a moisture meter wouldn't measure and oil base stain if it's testing water's electrical conductivity. I suppose if you take before, during and after the accuracy wouldn't be as important as verifying the conductivity has returned to its original level.
The Following User Says Thank You to Metro M & L For This Useful Post:
Old 09-30-2011, 11:11 PM   #9
astor's Avatar
Trade: FI
Rewards Points: 704
Oil based stains takes at least two-three days to dry, depends on humidity level, temperature,air circulation etc.
After two-three days, I apply in a closet 4" x 6" area water based finish with microfiber pad and wipe it to clean with white cloth, any un-dried stain pigments shows.If it is a little, it is ok,it will show some even after two weeks,check area to see any stain movement marks. Somehow you can able to tell with experience I guess.
astor is offline
The Following 2 Users Say Thank You to astor For This Useful Post:
Old 12-13-2011, 03:14 PM   #10
tom wentzwood's Avatar
Trade: Hardwood flooring
Rewards Points: 25
I think having dogs my self and wood flooring the largest issue here is the nails wich need to be maintained it would not matter what kind of finish you put down dogs nails need to be addressed. good luck with that www.wentzwood.com
tom wentzwood is offline
Some advice on selecting the right finish michaelsaam Painting & Finish Work 0 02-28-2011 08:50 PM
Gloss Lacquer to Satin Lacquer Finish ak_aiken Painting & Finish Work 7 08-05-2009 10:34 AM
What is waterborne hardwood floor finish? hardwoodfloors Flooring 3 07-14-2009 10:03 AM
Finish to Glossy - How do I fix it? lot249 Painting & Finish Work 8 03-03-2009 10:57 AM
