Trade: Roof
Grout Width And Sealing.
Hello all,
Probably a common question but here goes. We are having our bathroom done with porcelain tiles. Stall hower floor I assume we should use sanded grout because the tiles are 3/16 apart on the sheets and it is more durable. My wife wants the smallest possible grout lines. Can I do 1/16 on the walls (6x6 tiles) and the very small bathroom floor (12x12 tiles)? If so is it ok to do that small of a gap on a floor with unsanded grout? I read the durability might not be so good for a floor. Also the contractor stated he does not seal the grout. Is that normally part of a job? If not should I do it? Is it necessary? Thanks you all!! |
Tile Contractor
Re: Grout Width And Sealing.
What types of roofing do you do?
Trade: Flooring writer
From everything I had seen or heard, I would think it would be fine.
Need help defining a flooring term? - Flooring Glossary Need advanced installation instructions? - Installation Guides |
Trade: Residentual and Commercial General Contractor
I just finished a bathroom with 1/16 inch gaps on floors and walls.It's ok to use non sanded grout on floor,because you should only use sanded for 1/8 or larger.Not only this job,but I've done this many times.It was even ok'd by my suppliers.Contractor's tipically don't seal because you need to wait a couple days to remove all moisture,then seal.We never seal immediatly,and refer this to homowner.
Trade: Tile installations
The type of grout used is determined by the grout joint, not whether it's a floor or a wall, all tight joints used with stone on floors is unsanded.
Sealing as part of the job depends on what was installed, if stone, I price it into the job and I do it, if just for the grout, I tell them what it would cost for me to come back in a week to seal it and 95% of the time, THEY will do it, but I will tell them how and with what product. |
#6 | |||
Tile Setter
Trade: Ceramic Tile, Marble, & Stone
Re: Grout Width And Sealing.Quote:
I typically seal everything, but not necessarily on every occasion. - Bob
Classic Tileworks http://www.classictileworks.com Ohio Tile and Stone Installation Contractor in the Akron area serving Summit, Portage, Medina, Stark, & Cuyahoga counties in Northeast Ohio |
Chief Toilet Mover
Trade: Bathroom Remodeling
Re: Grout Width And Sealing. |
