Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Flooring
Old 05-20-2008, 09:01 AM   #1
egotistical prick
Cdat's Avatar
Trade: Wood Inlay
Grout vs mortar
Dumb arse question from a dumb arsed fool. I've been doing quite a bit of concrete work lately and have come to a issue that no one can give me an answer to. I do a lot of acid staining on concrete to enhance the look. Is there any reason, that you know of, why I could not stain a grout? Everyone I talk to is very much against the idea but they can give me no reasons why. My business is shifting to recreating the looks of stuff already done. So, I ask the tile guys here, or anyone who may know, why can I not acid stain grout?
Cdat is offline   Reply With Quote
Old 05-21-2008, 08:35 PM   #2
tile contractor
Bill_Vincent's Avatar
Trade: Ceramic and stone tile contractor
Send a message via ICQ to Bill_Vincent Send a message via MSN to Bill_Vincent
I don't know enough about ACID staining to answer intelligently, but I DO know grout can be stained. Even grout colorants notwithstanding, years ago, I built a home down in Terryville, Connecticut. When we first built, I used a bone colored glazed porcelain tile for my kitchen backsplash, and let my wife talk me into using a bone colored grout to match. My own taste is for slight contrast in grout, and after a while it really started getting to me. My wife was big into the Pfaltzcraft Yorktowne dishes, so I took a bottle of colonial blue ceramic stain from her ceramics kit, and used an artist brush to stain every last bit of grout on that backsplash. it looked pretty good when it was done, too. I've also used black shoe dye back before colorants came around, as well.
"Whether you think you can, or you think you can't, you're probably right."
http://www.creativeceramicandmarble.com
Bill_Vincent is offline   Reply With Quote
Old 05-21-2008, 08:47 PM   #3
Starving Tile Artist
wizendwizard's Avatar
Trade: Carpentry, Flooring & (UGLY) Tile installs.
Send a message via Yahoo to wizendwizard
Food coloring to stain silver grout a raspberry color.
Customer wanted to change colors but didn't have the budget to chip and regrout.
One of the coolest things I've ever thought of. 1991
"If you start the grout process over, you too could use sparkly grout!"
Columbia SC Tile Installer
http://www.adepthomerepair.com
Adept Home Repair Services
wizendwizard is offline   Reply With Quote
Old 05-22-2008, 02:10 PM   #4
Tile Contractor
I suppose you could stain a Portland grout with acid stains intended for concrete but grout installation is different from concrete installation.
The finish on a concrete slab comes from the working of the surface without overworking it. The aggregate is pushed down below the surface and the "milk" rises to the top allowing a smooth finish of sorts. It is (then) this milk after it cures that causes the variances in the appearance of the acid staining (etching) process. The acids work on the different chemicals that are present in the milk layer and this is what delivers the color matrix that results.
I doubt acid staining tile grout would produce the same satisfactory results.
Bud Cline is offline   Reply With Quote
Old 05-23-2008, 09:04 AM   #5
egotistical prick
Cdat's Avatar
Trade: Wood Inlay
Thanks for the answers. I've been staining grout but people freak out when they see me do it. I was just hoping for a reason if it isn't allowed and a reason why it could mess up the bond of the grout or something like that. I don't plan on quitting unless what I am doing will mess something up down the road.
What I've noticed more and more as I switch from wood to concrete, is the only reason something hasn't been done in the past, is nobody has tried it yet.
Colored Mortar ophnurse Masonry 8 02-14-2009 09:50 PM
Tile grout color too light fsbr Flooring 18 11-29-2007 06:05 AM
Mortar Bedding for Stone on Concrete Question. lukachuki Masonry 10 05-26-2007 09:09 PM
Changing mortar color? kcrossley Masonry 1 12-17-2006 01:44 AM
best way to seal grout for glass mosaics. ApgarNJ Masonry 2 06-27-2006 05:18 AM
