Remodeler
Grout Problem
I have a customer who has a problem with grout, it was laid about 3 months ago, and upon inspection it looks like along one side of the tile to have hairline cracks in it, it looks like its shrunk to me, i checked the tiles and none are loose, ive never seen this problem before, has anyone? is there an easy fix - or is it as i suspect a case of raking out and regrouting?
Damned if im gonna do it more than once. |
Trade: Tile installations
Re: Grout Problem
Was it cement based grout or pre-mixed, what size joint, sanded or unsanded grout used?
If all of above tells me it's fine, there's movement in the floor.
#3 | |
Remodeler
Re: Grout ProblemQuote:
Chief Toilet Mover
Trade: Bathroom Remodeling
Re: Grout Problem
I'd bet PeeWee Herman's left one that it is movement. Cracked grout = movement everytime.
Remodeler
Re: Grout Problem
ok ty, now to find a way to fix it.
#6 | |
Chief Toilet Mover
Remodeler
Re: Grout Problem
well caulk would be better than taking it up, and if i rake out 2/3 of grout, will have something to adhere to. Thanks for the suggestion will save me some time and the HO money too.
Chief Toilet Mover
Re: Grout Problem
...and I didn't even have to get the bullhorn out!
Trade: remodeling/specializing in kitchen & baths
Re: Grout Problem
sounds like deflection. problem w/ underlayment
soft subfloor? underlayment over vinyl ? |
Re: Grout Problem
OK, there's movement in that floor, forget about caulk or regrouting, this floor will only get worse in time, poor installation and subfloor preperations, there's MOVEMENT and it shouldn't have been set over the plywood alone.
The only fix is to redo the whole floor again, CORRECTLY. |
#11 | |
Remodeler
#12 | |
Remodeler
Re: Grout Problem
Thanks, i did not do the tiling just got the job of repairing, after repainting the house. Seems like more than i want to do, maybe they should call back the tiler.
Remodeler
Re: Grout Problem
This gets better, after speaking again to HO i find that tiler laid down backer board on top of the advantech, so i take it this means some sort of movement? Any fix - i suspect i have to get underneath and pin somehow?
Chief Toilet Mover
Re: Grout Problem
A backer board isn't a cure for too much flex in the floor. It can be part of the cure though.
Re: Grout Problem
Sounds scary:
Getting called-in to 'fix' something that may actually need to be completey re-done. That always gets our hairs on end..... Depending on the issue. You could be walking into something that someone else REALLY screwed up, and then.....once you get involved (trying to do a 'repair' on it).....they call you back when it cracks again...or cracks in another spot..... Next thing you know, you are now the 'scape goat' for taking responsibility of 'fixing' it. Just my 2 cents... (Been there and RAN like heck from getting involved...) If you do decide to take it, make sure that you put a clause in your contract. .... We do, if we did not actually 'start' the job, We will do our best to fix, but we won't put our name on it, since we don't know what the 'other guy' actually did - that we cannot see.
- Build Well - Last edited by AtlanticWBConst; 05-16-2006 at 09:06 PM. |
Chief Toilet Mover
Re: Grout Problem
That's some good advice.
#18 | |
#19 | |
#20 |
Trade: Home Improvement Handyman
Re: Grout Problem
I never use grout around the Perimeter. Colored caulk works the best.
| Grouting over Grout? | c5150b | Ceramic & Stone Tile | 13 | 05-22-2007 07:44 PM |
| Well problem | paintr56 | Plumbing | 10 | 02-09-2007 09:20 AM |
| Grout width query. | Nick S. | Ceramic & Stone Tile | 18 | 10-12-2006 10:22 PM |
| Strange Fly Problem | johnnymac | Plumbing | 4 | 09-07-2006 02:30 PM |
| best way to seal grout for glass mosaics. | ApgarNJ | Masonry | 2 | 06-27-2006 06:18 AM |
