Grout Over Grout
Old 12-03-2017, 10:00 PM   #1
VRNorthwest's Avatar
Rewards Points: 18
Grout Over Grout
So, I am working on a shower with tumbled travertine 8"x8" and the grout lines are 1/4", wavy and it will be extremely hard to remove all the grout in this 5X3X8 shower. the grout in the corners are cracked, and there is a few spots in the middle of the tile that also has cracks.. I'm concerned as to what is causing the cracks in the middle of a wall, and I am not going to warranty anything. I'm going to remove the grout what is cracked, and strip the rest. This is probably a cheap polyblend sanded grout and I plan to use a good laticrete over the old grout and in the newly removed areas. Do you think after striping that the new grout will bond to the old grout? Or is this just a tear out? I dont want to try and scrape all this grout out because there is just too much labor involved IMO. thoughts? Thanks!
VRNorthwest is offline
Old 12-03-2017, 10:04 PM   #2
Xtrememtnbiker's Avatar
Trade: General Remodeling
Rewards Points: 866
Re: Grout Over Grout
I'm not sure what you mean when you say you will strip the rest. Not sure what product you would be using for that.
But anything short of cutting out the old grout and getting new grout install a proper specs is a waste of time and your clients money. You can't "skim" grout over old grout with any success.
I agree with you that I wouldn't want to cut it out. I'd personally want to sub that to an outfit that does it. Let them have all the fun.
Xtrememtnbiker is offline
Old 12-03-2017, 10:16 PM   #3
Rewards Points: 18
https://groutinfo.com/product/comlet...loor-care-kit/ This is what I plan to use to clean/strip and scrub the grout.. I was thinking to skim over to fill any holes or gaps, because its the tumbled travertine which has lots of missed holes and the original grout job was splotchy. I mainly am looking to fill all those holes, etc.. and then seal, and caulk so no more moisture can penetrate the tile/grout
Old 12-03-2017, 11:38 PM   #4
tjbnwi's Avatar
Rewards Points: 3,634
Track saw with an ATS diamond blade.
tjbnwi is online now
Old 12-04-2017, 12:46 AM   #5
Frank Castle's Avatar
Rewards Points: 1,140
Well,
Aren't you fancy?!
Thanks, I learn something new here almost daily.
Adapt, Improvise, Overcome.
Frank Castle is offline
Old 12-04-2017, 04:47 AM   #6
Big Johnson's Avatar
Trade: Contractor and Grunt
Rewards Points: 3,788
That mosaic will be fun.
Big Johnson is offline
Old 12-04-2017, 07:18 AM   #7
AustinDB's Avatar
Rewards Points: 682
What if you have mold behind the travertine? The grout may be failing because the travertine wasnít/hasnít been sealed so water has infiltrated the stone.
Great idea Tom!
AustinDB is online now
Old 12-04-2017, 08:27 AM   #8
tjbnwi's Avatar
Nothing to it. Much more controllable than a hand grout saw.
Old 12-04-2017, 08:42 AM   #9
kirkdc's Avatar
Trade: Remodeling (mostly kitch/bath)
Rewards Points: 2,796
I'd sell them new tile job. Bid tree fiddy.
kirkdc is offline
Old 01-26-2018, 11:03 PM   #10
rblakes1's Avatar
Rewards Points: 1,554
Man, now I gotta add those suction cup things to my wish list...
Sent from my SM-N910V using Tapatalk
rblakes1 is offline
Old 01-26-2018, 11:25 PM   #11
Unger.const's Avatar
Rewards Points: 2,682
How do those cups work on not smooth surfaces?
Unger.const is offline
Old 01-26-2018, 11:29 PM   #12
Rewards Points: 866
What do you consider not smooth surfaces? If it doesn't seal, it won't hold.
Old 01-26-2018, 11:37 PM   #13
tjbnwi's Avatar
You'd have to try them surface to surface. Mounting tape if the Gecko's don't work.
Old 01-27-2018, 08:36 AM   #14
kirkdc's Avatar
I guess we'll never know how the story ends.
And not even a thank you. No respect I tell ya'... no respect...
kirkdc is offline
Epoxy Grout CharlieDelta Tiling 6 04-11-2017 07:28 AM
Block grout requirements. dom-mas Masonry 7 02-24-2014 06:52 PM
Grout or silicone ? power Masonry 6 04-21-2013 06:16 AM
Marble Wall / Floor Grout Maintenance ? We Fix Houses Tiling 4 08-14-2012 12:00 PM
Grout in Textured Tile Tips DemRem Tiling 28 07-16-2012 05:58 PM
