Grout In Corner Of Tile Shower
Old 02-19-2018, 07:31 PM   #1
aweikel7's Avatar
Trade: Industrial Electrical - Project Manager
Rewards Points: 12
Hello!
I'm planning on repairing a cracked grout line in the corner of a shower for a family member. Looks like the subcontractor for the GC used grout instead of a silicone.
To do this, I was planning on using my oscillating saw to remove some of the grout and create a gap for the silicone.
Is that the correct way of going about this?
Thanks in advance!
Andrew
aweikel7 is offline
Old 02-19-2018, 07:34 PM   #2
FloorsByAlex's Avatar
Trade: Flooring
Rewards Points: 58
Re: Grout In Corner Of Tile Shower
Originally Posted by aweikel7 View Post
Hello!
Thanks in advance!
Andrew
Yes
Always sanded silicone in corners
And yes use multitool to remove grout and cheap grout saw
Sent from my LG-LS993 using Tapatalk
FloorsByAlex is offline
The Following User Says Thank You to FloorsByAlex For This Useful Post:
aweikel7 (02-19-2018)
Old 02-19-2018, 08:37 PM   #3
AustinDB's Avatar
Rewards Points: 652
if you're going to use a multitool to remove the grout in the corners, don't go too deep and penetrate the layer of waterproofing. That could potentially be a worse problem in the future than cracked grout with a functioning waterproofed wall or pan.
AustinDB is offline
The Following 3 Users Say Thank You to AustinDB For This Useful Post:
aweikel7 (02-19-2018), KAP (02-20-2018), Rio (02-20-2018)
Old 02-19-2018, 08:40 PM   #4
Peter_C's Avatar
Trade: Home Beautification
Rewards Points: 1,668
I would manually pick as much of the wayward grout out as possible. Even using a hammer and spike to knock it loose. Breaking it out is less likely to do damage, vs a power tool. Assuming it is already coming loose, which is why it needs replacement.
Then put masking tape to protect the tile and go at it with a multi-tool.
Peter_C is online now
Tile in an outdoor shower. offshorehs General Discussion 3 06-22-2013 06:22 AM
Wall tiles in shower ? #1 Handyman Tiling 14 06-25-2012 09:45 PM
Tile grout cleaner products? TIGHTER MITER Tiling 13 02-02-2012 12:54 PM
Tile over existing shower surface SK Builders Tiling 16 07-06-2009 12:42 AM
