Grout Boost
Old 01-18-2012, 07:36 PM   #1
bluebird5's Avatar
Trade: Licensed G. C. carpenter, flooring, remodeling
Rewards Points: 694
Grout Boost
I was at blows looking in the tile section to see if they had upgraded from the first spectralock to specta lock pro or pro premium which brings me to my first wandering. Why the heck would anyone want to use the old specralock? Anyways I saw a product called grout boost and was reading and it said you add it to cementious grout in place of water and it never needs sealing and it makes it stain proof. Anyone use this? Does it clean up easy as regular grout?
bluebird5 is offline
Old 01-18-2012, 07:40 PM   #2
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Rewards Points: 1,114
Re: Grout Boost
It's a Mapei product and it's basically a latex additive for cementitious grout. Same concept as Laticrete 1776.
Angus
angus242 is offline
Old 01-18-2012, 08:09 PM   #3
Orlando Car
Floormasta78's Avatar
Trade: certified floor covering installer.
Rewards Points: 1,154
Re: Grout Boost
I'm a Laticrete user only, why would I use the old spectralock, well is its available , no problem, with the new one, only makes my life easier.
http://www.facebook.com/#!/certifiedfloorcovering
Certified Floor Covering
Serving All California
( 510 ) 760 - 6810
Floormasta78 is offline
Old 01-18-2012, 08:14 PM   #4
cleveman's Avatar
Trade: custom home building
Rewards Points: 2,624
Re: Grout Boost
I think the clean up is a bit more difficult. I just use smaller batches. Try to give yourself as many advantages as possible. Use a sealer first, wet first, etc.
cleveman is offline
Old 01-18-2012, 08:18 PM   #5
tileman2000's Avatar
Trade: tile contractor
Rewards Points: 528
Re: Grout Boost
Same here Orlando, I used the older version Of Spectralock so much that it's like using a regular cementious grout.
I've used another product that's added to grout that eliminates the need for sealing, but it's kinda new and the verdict is still out.
Michael
Miller Tile on Facebook
tileman2000 is offline
The Following User Says Thank You to tileman2000 For This Useful Post:
Floormasta78 (01-19-2012)
Old 01-18-2012, 10:06 PM   #6
Orlando Car
Re: Grout Boost
I did a job for a guy that provided me with everything , including this garbage..
( 510 ) 760 - 6810
Old 01-19-2012, 05:33 AM   #7
Rewards Points: 528
Re: Grout Boost
Next time tell him not to do you any favors.
Michael
Old 01-19-2012, 05:51 AM   #8
Doer of Many Things!!!
gideond's Avatar
Trade: Paint and Floor Covering Retailer
Rewards Points: 1,135
Re: Grout Boost
The Grout Boost sold at Lowes is a TEC product. It only works well with TEC grouts. It's basically a liquid polymer. TEC grouts do not have a dry polymer added so the additive works okay with them. Other brands of grout like Mapei and Laticrete have dry polymers already in them. Adding TEC Grout boost puts too much polymer in and makes it a sticky mess to work with. I know Mapei came out with their own version of this with less polymer in the liquid that will compliment their grouts better.
gideond is offline
The Following User Says Thank You to gideond For This Useful Post:
Metro M & L (01-22-2012)
Old 01-19-2012, 08:42 PM   #9
CO762's Avatar
Trade: Organic Mold Farmer
Rewards Points: 4,534
Re: Grout Boost
I've used GB once. sad sack HO got nailed by some chain tile store, but I tried it as they paid something like $80 for it. I didn't like the mix of it, so I added some water and it turned out pretty well. Went in easy, cleaned up easy, but sucked every last molecule of moisture out of our hands up through the shoulders and around your back and down the legs to the ankles, out the feet and into the water supply.
I have no idea how well it works over time though. I'd try it again in a small area, especially since the price somehow may have comedown.
CO762 is offline
The Following User Says Thank You to CO762 For This Useful Post:
Old 01-19-2012, 09:19 PM   #10
cleveman's Avatar
Re: Grout Boost
The Mapei stuff and the TEC stuff is expensive.
HD sells some which is the least expensive at $22/40 oz. I believe.
But who knows what is in each bottle?
It was my understanding it was supposed to help with efforvescence/make everything look more uniform.
cleveman is offline
Old 01-21-2012, 09:03 PM   #11
GO Remodeling's Avatar
Rewards Points: 96
Re: Grout Boost
Used it once, too. used the exact ratio to start but found it too dry so I added more (purchased an additonal bottle just for this situation). Didn't like it.
GO Remodeling is offline
Urethane Grout Installation Tidbits angus242 Tiling 100 05-13-2013 03:23 PM
Grout Boost?...Whatcha think? Aaron Tritt Tiling 6 03-19-2011 11:57 PM
grout stains unavoidable? MichaelEmerson Tiling 32 02-27-2011 06:56 AM
Grout sealer Jer Tiling 7 12-19-2010 02:50 PM
best stain-resistant grout for glass tile rock nohow Tiling 3 10-10-2010 05:58 PM
