I can't stand Bostik's BEST!!! The trowel ridges slump, like the MVP does, Meaning, you better make sure the concrete is as flat as a pane of glass. 3/16 in 10, no longer applies. It better be 1/16 in 10!!!!
I like Bostik's BST, a lot better.
What I recently got a chance to use and it was sweet, was the new Mapei PlaniSeal WFM, which is almost exactly like Bostik's, MVP. It slumps a lot better then MVP.
I also got a chance to use the Mapei 990 adhesive. Worked sweet.
The manufacture states that it is to be installed as if it were solid flooring
Although I have not had a chance to play with that particular board, all bamboo is very unforgiving where swings in rH are dramatic between seasons, or if they travel a lot and let the interior green house.
