Granite Floor Restoration
Old 09-03-2006, 02:43 PM   #1
Home Improvement Guy
ron schenker's Avatar
Trade: Renovations contractor
Customer has a granite floor in the front entrance hallway that looks beautiful but feels uneven under bare feet. Some corners are not the same height (off by about 1/32 lippage) and other tiles are slightly low along the edges. Rather than redo the whole floor, would a restoration job work? Grinding, honing, and polishing isn't cheap but probably less messy and expensive than tearing it out and laying new tile. I have little experience with this restoration process and will contract it to a pro....
Don't worry, the baseboard will hide it!
ron schenker is offline
Old 09-03-2006, 03:59 PM   #2
Re: Granite Floor Restoration
Here's a picture.
Old 09-03-2006, 04:06 PM   #3
Teetorbilt's Avatar
I think that you answered your own question. Call in the pro's.
Albert Einstein
Teetorbilt is offline
Old 09-03-2006, 06:04 PM   #4
reveivl's Avatar
Trade: Renovations
How 'bout tell 'em to relax, ignore it and send them a bill for consulting? I mean 1/32"? What are they doing on it? Playing shuffleboard?
I know, I know, the customer is always right bla bla. Just venting, Rich.
reveivl is offline
Old 09-04-2006, 03:31 AM   #5
415moto's Avatar
Trade: General contractor
nah, i agree. 1/32 lippage? holy hell. 1/16 (if thats a 1/8 grout line) to 1/8 yeah i can see. but 1/32. go to a mall thats likely done with union setters and take an edge to the floor, youll find spots with even 1/8 of lip...and thats likely with a 1/4 grout line.
415moto is offline
Old 09-04-2006, 07:53 AM   #6
Very picky HO in a $800,00 home who loves to keep up with the Jones's and if they can't slide along the floor in their stocking feet smoothly, they're not happy.
BTW, there are some spots that are up 1/16"
Is there some kind of hard acrylic type sealer that can be applied and kinda self level the floor without grinding, and honing.
Old 09-04-2006, 12:10 PM   #7
jvcstone's Avatar
Trade: Masonry / architectural stone carving
Ron,
You might find some sort of acrylic top coat for the floor, but that would be the absolute worst thing that could be done to the stone, and lead to all sorts of other trouble down the road. In my mind, that is not excessive lippage for tiles of that size.( well the 16th might be) Home owner wants a perfectly flat surface--than only thing that can be done is a grind in place and re-polish. It will cost $$$$.
JVC
John VanCamp
www.jvcstoneworks.com
jvcstone is offline
Old 09-04-2006, 01:27 PM   #8
JVC...have you got a rough idea on the cost to grind and polish 220 sq.ft.
Old 09-04-2006, 06:26 PM   #9
tile mason
MattCoops's Avatar
unless they plan on ice skating on it, I don't think a 1/32" difference is all that severe
The reason for this is simply the tile was laid with improper thin-set application. There can be spots (such as corners) where there was a glob too much of thin-set applied.
If they are that much perfectionist, mark the tiles that need to be "leveled" and come up with a price per tile to rip up, scrape sub clean, lay tile, grout, clean, and seal.
If the homeowner has a box of the tile hanging around, get product # and head to local tile supplier to get price
grinding, polishing will be very much a headache
and you'll probably end up with more work to do
MattCoops is offline
Old 09-04-2006, 09:21 PM   #10
jvcstone's Avatar
Ron, this is something that I don't do, and the price would vary from location to location. Since there is a policy about mentioning other sites here, I'll PM you a link.
JVC
John VanCamp
jvcstone is offline
Old 09-14-2006, 11:05 AM   #11
hipo.wong
Guest
hipo.wong's Avatar
Posts: n/a
I agree with reveivl,that's not a big deal
Old 09-15-2006, 04:14 PM   #12
Tile Contractor
Bud Cline's Avatar
MattCoops: "Unless they plan on ice skating on it, I don't think a 1/32" difference is all that severe
The reason for this is simply the tile was laid with improper thin-set application. There can be spots (such as corners) where there was a glob too much of thin-set applied."
Let's examine this issue for a moment or two. First of all this lippage occurance probably IS NOT the result of "a glob too much of thinset applied". That makes no since. When thinset is spread globs or no globs the viscosity is going to be the same. When using a notched trowel there are no globs as a rule. Granted an abubdance of thinset in an area could result in an elevation variable but not very likely. The thinset will disburse itself along the plane of the tile bottom fairly evenly, globs usually wouldn't be present and if they were they wouldn't necessarily be a problem.
I should mention that 1/32" lippage variable is within industry tolerance and frankly this conversation is just for fun cause there is nothing wrong with that floor.
Moving along......
1. The problem is more than likely either a variance in the thickness of the stone slab (tile) as it comes from the manufacturer, which also has acceptable tolerances.
2. All stone tiles have the ability to warp. Warpage by-the-way also has acceptable tolerances within the industry. It would not be at-all unusual to have some granite tiles with which the corners are experiencing some warpage.
3. The substrate may have been out-of-plane (which is probably the true cause) or the lippage may be occurring at a seam location if the subfloor was originally wood and CBU was applied. If the subfloor is concrete then God knows how flat (plane) concrete is and that some measures to plane the surface are usually required before installing a stone tile.
All-in-all I am reasonably sure that "globs" are not the cause and that the floor is within acceptable standards set-forth by the industry. If it doesn't meet the "socks test" that doesn't mean redoing the floor will result in anything better than what exists now. I doubt it will.
In my personal opinion, this is one of those jobs that a guy should stay away from. Right now (ron) it isn't your worry and if you contract to redo an already acceptable job you have then bought the next failure lock-stock-and granite.
This stuff is all in books and readily available to anyone that cares to make a small investment in their future and their trade. That floor is a good one, if it ain't broke don't fix it!
www.tileusa.com (tca publications)
A137.1
A108.1A3.3.7
TO OUR VALUED CUSTOMERS:
Please manage your children.
Any children unattended throughout the day
will be given a Free Mountain Due at our regular quiting time.
Bud Cline is offline
My fault or the granite guy's? john elliott General Discussion 86 01-17-2011 03:48 AM
flagstone set on granite gravel Jacey Landscaping 2 08-12-2008 09:38 AM
Granite countertops sidejobs Finish Carpentry 3 05-09-2007 05:53 PM
Reusing granite countertops alphacwh Remodeling 5 02-12-2007 06:37 AM
Granite or Slate ron schenker Flooring 6 07-19-2006 06:20 PM
