Good Sheet Vinyl
Old 02-28-2009, 05:46 PM   #1
Good Sheet Vinyl
Normally I send the HO out
to pick their own vinyl, and
stay completely out of it.
This however is for my sister,
and she's 400miles away (Racine.)
Would like to know a good heavy
sheet vinyl that doesn't have too
spongy a backing for a bath with
a claw foot and some other heavy
stuff in it.
Guidance is appreciated.
neolitic is offline
Old 03-01-2009, 09:58 AM   #2
Sean
SLSTech's Avatar
Re: Good Sheet Vinyl
I almost always go with Armstrong
There will always be a compression that occurs with heavy objects - less compression with commercial or linoleum (the real stuff)
If you want it to last a long time & she likes the looks - I would go with the commercial brands, they have gotten a lot better lately (i.e. don't look so sterile)
Now that we have bumped this thread up, we might get a few people in that install it every day & their takes on it
SLSTech is offline
Old 03-01-2009, 10:02 AM   #3
mdshunk's Avatar
For about the last year, I've had several hundred yards of the Flexitech vinyl put down all over. Self healing, doesn't scuff, pressure sensitive adhesive. Man, that stuff is great.
mdshunk is offline
Old 03-01-2009, 10:07 AM   #4
Thanks guys, I'll check back when I
get up there (Chedarland) this evening.
I know some of my customers have used
Armstrong, but I don't know which lines.
Some seem to be heavier, and have less
sponginess in the backing.
That's what seems to hold up best, long term.
I'll look into the Flexitech md...thanks.
neolitic is offline
Old 03-02-2009, 12:47 PM   #5
Flooring Guru
Floorwizard's Avatar
Trade: Sales Manager
True Lino is great as well.
Floorwizard is offline
Old 03-02-2009, 02:17 PM   #6
Real linoleum is my choice as well,
but i know no installers in Wi. and
and experienced guy would seem to be
a must for that.
neolitic is offline
Old 03-02-2009, 03:42 PM   #7
Flooring Installer
rusty baker's Avatar
Trade: flooring
This will tell you about IVC vinyl.http://vinylflooring.org/movie.html
rusty baker is offline
Old 03-02-2009, 05:42 PM   #8
Flooring Guru
I think IVC has too much cushion for a clawfoot tub.
Armstrong inlaid residential would be great but they dont make it anymore.
Commercial inlaid is harder to clean....
Lino would be best as far as sheet goods.
Old 03-02-2009, 06:05 PM   #9
Flooring Installer
Trade: flooring
I agree, but I assume this is a DIY. Lino can be difficult to install.
Old 03-02-2009, 06:12 PM   #10
mdshunk's Avatar
What's the stuff they use in commercial installs where they heat weld the seams with some kind of filler rod?
mdshunk is offline
Old 03-02-2009, 06:27 PM   #11
"da Whale don't hesitate"
PrecisionFloors's Avatar
Trade: Hard Surface Flooring
Both commercial vinyl and linoleum are weldable floors, shunk. Neolitic is correct in the assumption that an experienced installer is needed with lino. It is a different animal than vinyl and requires a few different methods different from a vinyl install. A properly installed, heat welded lino would last longer than than the bathroom would be in style.
Precision Flooring
(772) 237-9900
PrecisionFloors is offline
Old 03-02-2009, 07:00 PM   #12
I've seen some beautiful, and pricy,
linoleum horribly botched.
One of many reasons I try to distance
myself from the sheet goods.
neolitic is offline
Old 03-03-2009, 12:46 PM   #13
Flooring Guru
Let's not forget this may be a 5x5 bath.
Hard to botch a drop bath.
no seams.
if seams......your right...ouch-
Old 03-03-2009, 04:23 PM   #14
no seams.
For the 5X5, even I can make
a template and do a nice job.
This one is a 100 yr. old
6-3X13-9 with offsets..........
neolitic is offline
Old 03-03-2009, 06:00 PM   #15
Flooring Guru
yeowch....
Old 03-03-2009, 08:26 PM   #16
Mike Costello's Avatar
Trade: Flooring
Send a message via Yahoo to Mike Costello
Bet you could make a template for that too
Mike Costello is offline
Old 03-03-2009, 09:58 PM   #17
Maybe, if she'd get rid of all
the damn furnitur in the LR
so I had a place to cut then.
But I'd much rather find someone
who actually knows what he' doing.
neolitic is offline
Old 05-16-2009, 11:01 AM   #18
nuwest's Avatar
Trade: Flooring+Interior Finishing
This may be late but go with Armstrong StrataMax
nuwest is offline
Old 05-25-2009, 09:57 AM   #19
Rkeister's Avatar
Trade: Flooring Professional
Armstrong Stratamax, or Mannington Naturals.
Rkeister is offline
Old 05-25-2009, 10:08 AM   #20
About six weeks late,
but thanks.
Got Floortech Interiors to lay
Marmoleum for her.
All's well.
neolitic is offline
Any one have a good choice on a good Planer? Houston's Tools & Equipment 22 02-24-2011 10:40 PM
ceramil tile over vinyl s.smith Flooring 13 01-14-2009 12:19 PM
good ceramic slide cutter SES Constructio Flooring 7 11-21-2008 11:20 AM
shingles sliding off, found reason, advice sought mlandman Roofing 26 03-28-2006 04:38 PM
vinyl sheet floor bidding / advice socialgen Flooring 9 06-06-2004 11:22 AM
