Glue Down On Concrete - Question
Old 10-29-2009, 12:10 PM   #41
Knowledge Factory
Floordude's Avatar
Re: Glue Down On Concrete - Question
"with neither saying anything about needing a second product applied for anything else, including a moisture barrier."
Originally Posted by JohnHomeMatters View Post
1. I asked about a vapor barrier. The contractor says he has a special glue that handles that, and use of an additional paint-on type barrier would negatively affect the glue down.
From the original post....
http://www.AustinFloorguy.com
Floordude is offline
Old 10-30-2009, 08:17 PM   #42
cprao's Avatar
Trade: potential contractor
Originally Posted by Floordude View Post
Besides Stauf 960, care to provide the proof needed, to back up your statement? Multiple, means more than one. Please list the multiples.
As a NWFA failure investigator, I have seen your thinking lead to many many failed installations.
Bostik's doesn't
Mapei doesn't
Frankin/Titebond doesn't
Taylor doesn't
Stauf 960 is the only adhesive that markets and advertises it is a one application moisture barrier and adhesive. It is only good to 8# per 1000 sq.ft. of moisture vapor emissions.
Bostik's MVP and Mapei WFM, are capable of restraining much higher emission levels.
Franklin's is a 2-part epoxy coating that is rolled on.
Taylor's is the use of there MS+, letting it cure out, and then another coat for adhesion to the wood.
Why would these adhesive manufacturers make a moisture blocker, if their adhesives where a stand alone, one application moisture barrier and adhesive?
Floordude, Based on your above statements,are Bostik's MVP and Mapei WFM are better than Stauf 960. Since the former products are restrain much higher emission levels. Please explain.
cprao is offline
Concrete Company delivered junk concrete. How best to pursue? marcomjl Concrete & Paving 46 08-07-2011 02:55 PM
Concrete finishing question bcbuilder32 Masonry 4 04-15-2009 11:58 AM
Lightweight concrete question Snood Flooring 7 03-04-2008 10:32 PM
Mortar Bedding for Stone on Concrete Question. lukachuki Masonry 10 05-26-2007 10:09 PM
Question regarding concrete roofing tiles. Oregon_Rob Roofing 3 01-16-2006 09:58 AM
