Trade: HVAC And Zone control Systems
Gloss, Semi Gloss Or Satin, Anything To Think About Other Than The Shine?
Well, I did a test patch of the no. 2 white oak with Min wax "provincial" oil stain and three coats of min wax oil based gloss poly, for the rustic look cabin, and the wife thinks its too shiny, and she is usually right on these topics (or its better for me if I say she is).
So, I would appreciate any comments on the three choices as it pertains to care, maintenance, durability, rustic look, and so forth. I know at least with wall paint gloss is the easier to clean and maintain paint, but I am not sure with floor poly. The cabin has wood on all the walls and ceilings of a lighter shade, lots of glass, its really more upscale rustic. thanks for the help, and to all those I have bombardred with questions, this could be the last of them! (but no guarantees). |
| The Following User Says Thank You to Texwing For This Useful Post: | mencheman (09-04-2009) |
Trade: custom home building
Re: Gloss, Semi Gloss Or Satin, Anything To Think About Other Than The Shine?
Gloss is unspeakable. Semi-gloss looks very cheesy. Satin is for you.
Trade: hardwood floor contractor 28 yrs.
The higher the sheen(or Estevez)the harder the finish will be...Satin will be fine for you...You can put 2 coats of semi or gloss and the last coat satin..
Thats interesting: does doing two coats of gloss or semi gloss and finishing with satin accomplish some other effect, as opposed to 3 coats satin?
#5 | |
Trade: GC/Remodeling
Re: Gloss, Semi Gloss Or Satin, Anything To Think About Other Than The Shine?Quote:
It uses up the gloss that you already bought
-Steve "The most beautiful thing we can experience is the mysterious. It is the source of all true art and science." ~ Albert Einstein |
Trade: Painting, flooring
I do two semi and top satin all the time. Looks great. Good depth to the finish but not glaring.
I did three coats satin once. Hated it. Looked like there was NO finish on the floor. |
Re: Gloss, Semi Gloss Or Satin, Anything To Think About Other Than The Shine? |
Knowledge Factory
The dulling agents in satin, can and will build as you add more coats, it can make for a cloudy look.
2 coats of gloss or semi, and the final coat of satin, keep the clarity to see the full beauty of the wood grains.
Trade: Pretty much anything with wood
When I've polyurethaned floors usually do two coats of high gloss and a third coat of satin to finish. Satin gets rid of the glare and the high gloss wears well because it is a harder finish.
Old school Ranger
Trade: flooring
I agree two coats of gloss one coat of satin
Excellant advice, thanks-we looked at a friend's hardwoods, dark with satin finish, and they just looked dull, dark, and lifeless. thanks for the help, and please keep commenting, it builds my case with my wife for something other than straight satin!
Trade: Union Journeyman Carpenter-Hardwood/Resilient Flr
If you've already got the info you needed/wanted... you can ignore this.
But to further explain: In oil-based poly, higher gloss is a 'more pure' product. Manufacturer starts with high-gloss and adds "ingredients" to dull down sheen. The more additives, the less shiny it will be. That's why the higher gloss is a "tougher" finish. Also why suggested to use gloss as base coat, then top with satin. In water-borne poly, it's the opposite effect. The satins are usually more pure product than the higher gloss sheens. Personally, I love the look of Bona Traffic Satin... it seems to have a dull "shimmer" that oils can't acheive. Not to mention the stuff gets HARD when cured!! and doesn't 'amber' over time, like oil and other waters will do. BTW - Minwax Floor Poly is not exactly high-end... which could be part of your problem too! (Also, Minwax stain is meant primarily for furniture & cabinets and may not be compatible with some floor poly = short AND long term problems) I'd suggest getting your finish at a flooring supplier/distributer. It might cost a little more (or a lot more, depending) But it will be worth it over the life of the floor!! --You typically get what you pay for when it comes to any kind of supplies-- Good Luck! Good Luck! |
Trade: Hardwood Floors
Although there is good argument for the hardness factor in gloss vs satin I think it is splitting hairs. Gloss level is more personal preference then anything. If hardness and durability were primary concerns then there are more durable finishes out there. As far as whether to uses satin, semi or gloss I perfer to mix my last coat 1/2 satin and 1/2 semi. Satin is to dull for me and semi is too shiny. Do not mix manufacters but mixing shine levels is ok. Follow directions and you should be fine. Mike
Trade: Painting, Flooring, & contracting
I have already applied 2 coats of satin oil-based urethane. Could I use Gloss or semi gloss on my 3rd coat? Just so it doesn't look so dull.
Knowledge Factory
No, it will be glossy and cloudy.
You did it backwards. 2 coats of gloss, and the last coat of satin.
Tile Contractor
Floordude,
Enjoli is a mole. Can't you tell? And it isn't the jumbo green Crayon that gives it away.
Trade: Floorist
Hah. A 'mole'? Sounds insidious. mole = non-contractor?
• • • Greatness is a result of focused, deliberate practice • • • |
#18 |
Trade: general contractor
Hi all,
New here, hope someone can give an opinion. We just had our floor done, natural hickory, dark brown stain, with 2 coats satin finish. The finish is so dull, hazy and cloudy, we are really disappointed with them. Floor guy wants another $1,000 to put a semi-gloss on, as per our request. But is this the answer? Do we mix 1/2 satin 1/2 semi? He wants $250 just to do a sample on the closet floor. Or do we just live with it. He claims since we're contractors, he assumed we knew what it would look like, but didn't give us a sample to approve. Your thoughts? Thanks. |
#19 | ||
Tile Contractor
![]() Quote:
#20 |
That's the kicker; he's our regular flooring sub. I guess he's getting divorced
so doesn't want to spend any money making us happy. Needless to say, we won't use him again. |
| Paint or stain on hardi plank? | Jer | Painting & Finish Work | 25 | 12-24-2009 01:10 PM |
| satin or semi gloss??? | tyler durden | Painting & Finish Work | 6 | 07-14-2008 08:59 PM |
| Latex semi gloss over latex semi-gloss? | send_it_all | Painting & Finish Work | 3 | 10-01-2007 10:59 PM |
| latex semi gloss over oil semi gloss - can it be done? | Zeebo | Painting & Finish Work | 13 | 09-05-2007 06:38 PM |
| Semi gloss on walls?!?!what do you think?? | lornmastro | Painting & Finish Work | 21 | 02-16-2007 10:52 PM |
