Getting Laminate Under Door Casing And Jambs
Old 09-01-2006, 12:54 AM   #1
Blackhawk's Avatar
Trade: i am a small remodeling contractor been at this most my life
hello again..most laminate floorin ive done has been the kind u lay flat and tap together locking it..well this job is Armstrong laminate and its a lil different its lays in at an angle then u push it on down locking it in place u have to do the hole row before rollin it on down so my question is how do u get this laminate under the caseing and jambs after u under cut them ? you cant lay this brand flat and drive it together cause it damages the laminate .. please help ty.
Blackhawk is offline
Old 09-01-2006, 04:44 PM   #2
MikeT's Avatar
Trade: Remodeling, Home Improvement, Decks, Etc.
Re: Getting Laminate Under Door Casing And Jambs
I am not a flooring expert but when working with this type of flooring, I usually build the floor outside the area where I want to install and then slide the assembly in to place as a unit.
Another option would be to use a hand planer and to plane off the lip on the tounge enough to allow you to tap and glue the two pieces together.
hope this helps
MikeT is offline
Old 09-01-2006, 05:19 PM   #3
Blackhawk's Avatar
Thanks Mike this is exactely what i did..i was just wondering if any of the old pro's might know a good trick or a better way...thanks again'
Old 09-01-2006, 05:59 PM   #4
Chief Toilet Mover
Mike Finley's Avatar
Trade: Bathroom Remodeling
Better answer than mine, I was researching about using a jack to jack the door, frame and wall up.
Mike Finley is offline
Old 09-03-2006, 10:51 AM   #5
my own boss
supercrew's Avatar
Trade: carpenter
Send a message via Yahoo to supercrew
i put the armstrong (the lowest quaility in their line) in a ex GF house. i fought that stuff the entire time..good thing was she replaced all the doors so i didnt have that headache....long warranty but fine print says if its not glued at the seams water voids it....guess what....glass of water gets spilled in the CENTER of the room....instant bubbles...countless phone calls and many more hours of replacing.......otherwise the girl loves the floor
supercrew is offline
Old 09-04-2006, 08:55 PM   #6
Shanklesbuilder's Avatar
Usually you can just whack it on the end with a tap block and get that last row to snap together.
Just use a jap saw or undercut saw to cut the botom of the door casing off. Put a scrap piece of the laminate on the floor then set the saw blade on top and saw away.
If it is really junk you might have to glue the last row. I just finished 450sqft of 8 year waranty res, 2 year war in commercial. It was a pain.
Good luck.
Shanklesbuilder is offline
Old 01-02-2008, 04:14 PM   #7
Traveling Floor Crew
RhinoFlooring's Avatar
Trade: The traveling flooring crew, Wood,Tile, Laminate, Stone.....Commercial or Residential we do it all!!
The way that works the easiest is to make the cut to fit and take a chisel and just shave the top of the locking system off ( its a little notch that sticks up ) then put a lite bead of carpenters glue in the groove to hold in place, just like the old school Pergo floors.
Note: you will need to do the butt and long joints
RhinoFlooring is offline
Weatherproof, stainable exterior jambs MKamis Finish Carpentry 1 07-28-2007 12:04 PM
Window jambs extend beyond drywall jstrand23 Remodeling 21 04-27-2007 12:00 AM
Casing on pre primed window jambs icfbunt Finish Carpentry 10 11-13-2006 09:30 PM
