Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Flooring
Old 05-01-2006, 09:39 AM   #1
Trade: Home Improvement Contractor
Garage Floor
Does anyone know if you can grind down a concrete floor to make it level and smooth. I have a house that the builder poured his own floor and did this to SAVE $ . Now the owner has water running in the corners and the garage doors won't sit flat on the floor because it's to unlevel.
Ram
Rambone is offline   Reply With Quote
Old 05-01-2006, 10:23 AM   #2
There are tons of concrete grinding and cutting companies. Look in your phonebook.
We'll have to grab a longer board. I forgot to put the wood stretcher in the truck today.
slowsol is offline   Reply With Quote
Old 05-01-2006, 12:28 PM   #3
Tile Contractor
Or......you may be able to top it with a Self Levelling Compound. Not all Self Levelling Compounds are suiatble for a wear-surface but some are. Mapie (I think) makes a Self Levelling Compound that is intended for a wear-surface and can even be acid stained if so desired.
Just a thought.
I have used floor planers and grinders on concrete many many times over the years but they all tend to follow the existing contours. I can't imagine how tuff it would be to grind only the highs and leave the lows, just can't see how this could be cost-effective.
Bud Cline is offline   Reply With Quote
Old 05-01-2006, 03:08 PM   #4
General Contractor
Funny, I just went through this! Instead of repairing the high's and lows we ripped out the floor and poured a new one. It was only a two car garage and took a total of three days to do. Two guys broke it all out in one of those days.
-Robert F
RobertF is offline   Reply With Quote
Old 05-01-2006, 03:14 PM   #5
Custom Builder
Glasshousebltr's Avatar
Robert, if that was a 4" or plus floor, and it had wire and or rebar, I'd say ya got some pretty hard working fellas there. Hang on to em, they arn't slackers.
Bob
Bob
Glasshousebltr is offline   Reply With Quote
Old 05-01-2006, 03:14 PM   #6
Professional Remodeler
firemike's Avatar
MODS - I think this is a double post---
firemike is offline   Reply With Quote
Old 05-01-2006, 03:38 PM   #7
General Contractor
Bob
Haha, luckily this was only 3 or so inches and just wire reinforced. Luckily for us no rebar Should've mentioned that in the first post
-Robert F
Old 05-01-2006, 03:50 PM   #8
Custom Builder
Yea, a few extra inches can make a world of diference.......now enough about my personal life weren't we talking about a floor.
Bob
Bob
Old 05-01-2006, 05:03 PM   #9
Oh ya and the spin to this is the garage has radiant floor heat.
Old 05-02-2006, 06:29 PM   #10
Trade: painter
Shouldn't the homeowner be able to go back on the builder to fix it right? If it isn't very old and they are the original owners then I would think that the builder would be responsible for it. If I was them I would consult a lawyer to find out what my options are before paying to have it done over again.
oldgoat is offline   Reply With Quote
Old 05-03-2006, 09:19 AM   #11
Trade: Residential custom home builder
You could use some self-leveller and lay porcelain tile.
Clint - carpenter, coordinator, webmaster
RowdyRed94 is offline   Reply With Quote
Old 06-02-2006, 02:04 AM   #12
Trade: color stain existing concrete,overlays,epoxy and new concrete
Ram
I would do an overlay and make water run were it's should. And level it all out.
ben dolan is offline   Reply With Quote
Laminate Wood Flooring Over An Old Garage Floor mjm0073 Flooring 1 01-30-2007 10:42 PM
Painting garage floor chuckdec Painting & Finish Work 8 10-10-2006 08:19 AM
...continued...garage floor drain progress carlspackler Plumbing 0 05-27-2006 01:54 PM
Insulating garage floor bob the builder Remodeling 1 12-21-2005 10:53 PM
Garage floor Luke's Dad Masonry 3 11-26-2005 11:48 PM
