Gaps In Pine Flooring
Old 01-24-2007, 05:40 PM   #1
georgia dawg's Avatar
Trade: general contractor - SFR
We installed and finished (sanding +3 coats poly) some t&g pine flooring about 6 months ago, and we now have a few gaps (about a quarters width or so). Go ahead and spank me for not checking moisture content beforehand, but any suggestions, even cosmetic ones, for eliminating or hiding the gaps short of ripping out the flooring?
georgia dawg is offline
Old 01-24-2007, 05:47 PM   #2
Insert title
dougchips's Avatar
Trade: Doors-Windows-Decks
Re: Gaps In Pine Flooring
The heat and dry air is causing them to shrink a little. Hardwoods like oak or maple will move less but they cost more.
dougchips is offline
Old 01-24-2007, 05:57 PM   #3
You're exactly right. We installed it in new construction before we had any conditioned space (long story w/ the utility Co.). Anyways, any suggestions for improving it now?
Old 01-24-2007, 06:06 PM   #4
Insert title
dougchips's Avatar
I am not in favor of adding moist air into a dry environment, so that is out.
In my living room (addition) we use a space heater (long story). I have maple tg floors. In front of the heater there are gaps between the planks. The wood is just dry, if I move the heater the same thing will happen within a few days and the other area will expand back. Take a piece of pine and leave it in a moist area for a few days and measure it. Now take the same piece of pine and leave it in front of a heat source for a few days and measure it again.
Solutions- Vinyl flooring or pergo.
Old 01-24-2007, 08:26 PM   #5
Master Craftsman
Big Dave's Avatar
Trade: Rustic interior woodwork
The only thing that I know to do is to take some hemp rope and a putty knife and press it into the gap. This is the way old floors were done. It still allows for movement. You can also stain the rope to better match the flooring color. Honestly though, a pine floor is gonna do that and mine will have a gap that big here and there and nobody has ever complained. It's kinda expected with that product.
Do one thing at a time, do it well, then move on.
http://www.bigdaveswoodworks.com
Big Dave is offline
Old 01-28-2007, 12:08 PM   #6
J&J Home Imp.'s Avatar
Trade: Flooring and Trim
Its wood and wood moves. Changes in temp. and humidity will have it changing all year long. Its wood thats what it does.
J&J Home Imp. is offline
Old 02-04-2007, 04:56 PM   #7
TURNER FLOORING
turner flooring's Avatar
Trade: Floor installation
Home depot sells all kinds of color match filler that dries like wood. They have soft putties that match as well.. wood does move. Usually you can do a moisture test on the floor prior to your next installation if that was the cause of the problem. That way you have the sign off if they still want it installed. this is normally on jobs of a sufficent size. Ones that have a high value cost or high replace value.
http://TURNERFLOORING2.com
http://www.TURNERFLOORING.com/
Flooring the world over...
turner flooring is offline
sawing old flooring 72chevy4x4 Carpentry 2 02-23-2007 08:40 PM
1x12 white pine shelving for flooring? georgia dawg Flooring 0 01-29-2007 09:37 PM
Hardwood Flooring - First Go at It DecksEtc Flooring 56 10-05-2006 01:41 PM
Flooring in Log home C.C.R. Flooring 7 09-05-2006 09:58 PM
Re-claimed Vertical grain fir Flooring Coop Flooring 5 11-13-2005 08:49 PM
