Gaps Around Doors - Flooring - Contractor Talk
Gaps Around Doors
Old 02-15-2018, 05:58 AM   #1
justnicksc's Avatar
Rewards Points: 16
Gaps Around Doors
The previous contractor did a horrible job. I have been cleaning up poorly installed trim and unfinished paint. The one thing I have been trying to find a solution for is these gaps around the door in the flooring. The home owner does not have any scrap flooring and needs an inexpensive solution. Any help would be appreciated.
justnicksc is offline
Old 02-15-2018, 06:56 AM   #2
TimNJ's Avatar
Rewards Points: 3,166
Re: Gaps Around Doors
Got a closet you can pull material out of?
Then put a piece of carpet in the closet.
TimNJ is offline
Old 02-15-2018, 07:00 AM   #3
90%-er
onmywayup's Avatar
Rewards Points: 1,606
Another option is to use a combination of a skil saw set to the flooring depth and a multi-tool to cut out a rectangle of flooring in each door jam, then lay in a different threshold into each door way. A complimentary piece of tile, marble, etc.
Not sure where in the house or how many doors you have, so that's a factor I guess.
onmywayup is online now
Old 02-15-2018, 07:01 AM   #4
90%-er
onmywayup's Avatar
You can also cut the door stop trim up a bit, then put in a piece of shoe moulding on each side of the door jam to cover the gaps.
Old 02-15-2018, 07:02 AM   #5
Big Johnson's Avatar
Trade: Contractor and Grunt
Rewards Points: 4,766
Craigslist Contractor.
Big Johnson is online now
Old 02-15-2018, 07:45 AM   #6
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 14,031
Bid it only if you want it. We're not obliged to take on every knucklehead problem that customers create for themselves....who then want an inexpensive fix.
That being said, drop some hardwood blocks in there, but it's a headache.
MarkJames is offline
The Following 3 Users Say Thank You to MarkJames For This Useful Post:
kirkdc (02-15-2018), pinwheel (02-15-2018), SmallTownGuy (02-15-2018)
Old 02-15-2018, 07:56 AM   #7
I think itís floating laminate????
Old 02-15-2018, 08:00 AM   #8
MarkJames's Avatar
Originally Posted by Big Johnson View Post
I think it’s floating laminate????
Shhh. (could be, or not)
Old 02-15-2018, 08:58 AM   #9
KAP's Avatar
Trade: Custom
Rewards Points: 29,480
That color should be a pretty easy match... it's going to cost her either a box of flooring to do it proper or you putzing around trying to make fix-its work while paying you extra labor to do so...
The former is the easiest for you... takes less time, easier to do, and she'll end up saving on labor and not having to buy other materials to retro-fit...
KAP is offline
The Following User Says Thank You to KAP For This Useful Post:
justnicksc (02-16-2018)
Old 02-15-2018, 09:05 AM   #10
General Contractor
greg24k's Avatar
Rewards Points: 7,516
Just get a piece of hardwood flooring, straighten out the gap and fill it in, and use color matching stain, or get a prefinished piece of flooring it looks like natural oak.
A while back did this repair in 12 units on one tract home development, they did the same thing (but it was inside the closet) and you could hardly tell. Got natural pre-finished pieces of flooring from HD.
greg24k is offline
Old 02-15-2018, 10:12 AM   #11
Mordekyle's Avatar
Rewards Points: 3,766
I think the homeowner already got their inexpensive solution.
Mordekyle is offline
The Following 3 Users Say Thank You to Mordekyle For This Useful Post:
KAP (02-15-2018), MarkJames (02-16-2018), Rio (02-17-2018)
Old 02-16-2018, 06:30 AM   #12
justnicksc's Avatar
Rewards Points: 16
Thanks, we got it fixed. My client is a member at my church and got taken buy a shady contractor. Come to find out no permits were ever pulled. Couple other guys have come out to help. None of the 3way switches were working and most of the wiring was not to code.
The Following User Says Thank You to justnicksc For This Useful Post:
greg24k (02-16-2018)
Old 02-18-2018, 11:39 AM   #13
Scleo1's Avatar
Trade: General Residential
Rewards Points: 2
Glad you got the solution figured out. Was going to suggest either a closet or dishwasher if you couldn't find the flooring. Otherwise it's best to get another box. She's lucky to have good people looking out for her.
Scleo1 is offline
The Following User Says Thank You to Scleo1 For This Useful Post:
justnicksc (02-18-2018)
Old 02-18-2018, 02:06 PM   #14
Dave in Pa's Avatar
Trade: restoration/remodeling
Rewards Points: 1,272
I hate to say it, seen this a few times, and had to "fix" it the best you can. BUT sometimes ya get what ya pay for, the "cheap" way out will get ya in the end!
Dave in Pa is offline
What's up with Unfinshed Maple Cabinet Doors? jpainting Painting & Finish Work 7 05-13-2016 12:34 AM
thicker doors interior? Spike7 Windows, Siding and Doors 17 12-16-2012 02:20 PM
Where do you get your doors & windows? JDK Building Windows, Siding and Doors 6 05-28-2010 03:49 PM
Doors, doors, doors Tinstaafl Carpentry 32 03-05-2010 10:13 PM
