Freshin Up Some Hardwood??
Old 05-01-2008, 07:53 PM   #1
dkillianjr's Avatar
Hey guys, One of my customers was asking me what she could do to freshin up her oak hardwood floor. It is only one 12'x16' room, the hardwood had carpet on it that she pulled up. The hardwood is in pretty good shape just a little faded. What do you think I should recomend she do? Maybe a light sand then a little poly or maybe some kind of wax or something?
Thanks, Dave
dkillianjr is offline
Old 05-02-2008, 08:09 AM   #2
egotistical prick
Cdat's Avatar
Trade: Wood Inlay
Re: Freshin Up Some Hardwood??
Go to your local department store and buy some neutral KIWI shoe polish. Take a cloth diaper and soak it in warm water. Wring out the excessive water. Daub the diaper in the wax and start buffing it onto the floor. It'll look like a sheet of glass when you're done.
22 cans of wax will suffice.
Cdat is offline
Old 05-02-2008, 08:12 AM   #3
genecarp's Avatar
that guy on tv. billy maze, some kind of orange shi# . mops right on, on the commercial anyway
genecarp is offline
Old 05-02-2008, 08:24 AM   #4
Steve
OCRS's Avatar
If the existing finish is poly, then a screen and coat
OCRS is offline
Old 05-03-2008, 01:00 AM   #5
dkillianjr's Avatar
Thanks guys, Maybe she can buy a 55 gallon drum of shoe polish
Old 05-08-2008, 12:38 PM   #6
Feedin the geese
Joining_heads's Avatar
Trade: Finish Carpenter
No wax, murphy's, orangeglo, or any other temporary freshener should be used. Who ever said screen/coat has the right idea.
If you put some wax or orangeglo crap a future recoat without sanding becomes a PITA as those products tamper the bonding ability between coats- no matter how well you scuff the surface. They do make bonding agents to add to the poly when this arises but even then they sometimes do not work all that well.
FWIW I prefer to use 120 grit sticky paper strips as opposed to screening because is leaves less marks.
Joining_heads is offline
Old 05-19-2008, 01:03 AM   #7
fast pasquale's Avatar
Trade: Hardwood flooring contractor
Shoe polish, No. If you wax it once the only way you can "clean it up" is to rewax..Nothng will stick to wax but wax. Screen and recoat is good. I just did a 7 bdrm mini mansion yest and today.
Chris Frate
Pasquale Floors
fast pasquale is offline
Old 05-19-2008, 02:15 PM   #8
SunSet's Avatar
Trade: Post Construction Cleaning
If it is a poly finish and she does not want to sand and recoat, Boni makes a chemical called Refresh. I cleaned an approximately 6 yr old house with black oak floors, the result was remarkable.
Make sure to throughly clean the floors.
If 99.9% of the cleaners sold in stores were used to clean it (Murphy's Oil Soap, Mop N Glow..... etc....) the Refresh may not adhere to the floors. Then your only solution is to sand and re-poly.
If she does this make sure she knows how to clean wood floors in the future. 99.9% of the people (that I have had association with) ruin their floors, not to mention voids the warranty, on their floors within a week of moving in.
SunSet is offline
Help Installing Hardwood over old/new Concrete Slab Hages Flooring 7 06-04-2008 01:02 PM
Tile and 3/4" Hardwood Transition Gap mobowhunter Flooring 21 01-23-2008 12:03 AM
Hardwood Flooring - First Go at It DecksEtc Flooring 56 10-05-2006 01:41 PM
Hardwood over hardwood? dkillianjr Flooring 9 09-21-2006 09:07 AM
Questionss on Hardwood underlayment and expansion newtofloor Flooring 8 11-24-2005 08:18 PM
