Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Flooring
Old 04-17-2008, 03:45 PM   #1
Trade: tile installer
flooring over flooring
I am a tile setter so I don't know much about hardwood flooring.
I am renting and I want to put laminate hardwood flooring over the existing hardwood in one of the rooms.
two reasons
One : to protect the existing floor
and Two because the color of the existing floor looks terrible
I don't want to deal with the landlord. and plan to take it out when I eventually leave
My question is do I need to put anything between the old and the new. Or can I just throw it down
It is a basic square room about 10'by 10'
Square pusher is offline   Reply With Quote
Old 04-17-2008, 03:59 PM   #2
Trade: kitchen & baths
yes you can, if your thinking of a laminate floating type floor. will have to install some typw of 3/4"x3/4" molding around edges and use a good quality foam pad under the flooring
onedelta is offline   Reply With Quote
Old 04-17-2008, 04:40 PM   #3
genecarp's Avatar
or a 3/8th moulding, if you keep it closer.
genecarp is online now   Reply With Quote
Old 04-17-2008, 09:31 PM   #4
Cpt. Chaos
PrecisionFloors's Avatar
Trade: Hard Surface Flooring
Gonna be pretty difficult to do, considering your expansion space should = 1/4". That only leaves an 1/8" for movement of any kind before it shows under the shoe molding. I don't like them odds .
Precision Flooring
Hampton, VA (757) 256-0848
Tile, Hardwood, Laminate, and Resilients
PrecisionFloors is offline   Reply With Quote
Hardwood Flooring - First Go at It DecksEtc Flooring 56 10-05-2006 12:41 PM
Question about floating wood flooring zoner11 Flooring 10 01-17-2006 05:04 PM
Hardwood Flooring For Large Projects StonewoodSP Marketing & Sales 1 12-08-2005 09:38 PM
Re-claimed Vertical grain fir Flooring Coop Flooring 5 11-13-2005 08:49 PM
Laminate Flooring Gina Flooring 9 04-27-2004 11:06 PM
