Flooring Over Concrete? Moisture Barrier?
Old 12-14-2007, 10:51 PM   #21
Re: Flooring Over Concrete? Moisture Barrier?
Originally Posted by Kevin75 View Post
The way I understand it, is that I put the barrier directly over the concrete, then build a sleeper system over that....then nail the wood flooring to the sleeper system. Yes?
That's what I do.
Avoid penetrations, cause then it ain't a vapor barrier anymore
neolitic is offline
Old 12-15-2007, 01:39 AM   #22
JPhelps's Avatar
according to nofma there are several ways to do it correctly. There are a lot of different methods people use and have found acceptable as well. I got one coming up that I decided I was going to use the floating subfloor method, which I think will be the easiest one(I may be wrong) But after leveling the concrete, laying out 6 mil black poly and floating 2 half inch sheets of treated ply that are attached to just each other at an angle somewhere in between parallel and perpandicular, and laying your wood on top of that, I'm excited about tryin it. I've heard it makes for a really nice walking floor. The other ones I have done the treated ply attached to the slab, which require the mastic and roofing felt because your putting holes in it. If you end in a doorway you'll have to completely remove the door and scribe the jambs to your transition, which are really easy to make with a table saw and an orbital sander. Start out with some 8/4 material, leave about a 2 inch area of the built up subfloor uncovered by hardwood where the transition will be....notch out the underside of thick material so that it lips up over the ply, and sits on the slab. then take it to the table saw and cut a slope on the face of it. You can leave about 3/8 on the leading edge, can't remember what angle I used, pretty sure I just eyeballed it. break over the edges with your sander. Transition stock needs to be at least 6 inches wide in my opinion. Sorry bout my explaining/typing, I make stuff run together horribly. You could glue these down, but what I have always done is screw and plug. I should just post some pictures on here so you could see, when I figure it out I will.
JPhelps is offline
Old 12-15-2007, 02:38 AM   #23
Jerry T's Avatar
Trade: Self employed - hard surface installer
No one has suggested this... but just for the record "do not" use any type pressure treated plywood for floating subfloors. Even if its a KDAT (kiln dried after treatment) it's too wet to use for this.
Jerry T is offline
Old 12-15-2007, 08:04 AM   #24
Edger Boy's Avatar
Trade: Wood Floor Contractor
Jerry, How can it be wet if it is kiln dried?
Edger Boy is offline
Old 12-15-2007, 03:26 PM   #25
Knowledge Factory
Floordude's Avatar
Prep the concrete to make it flat. Let that dry.
Asphalt mastic and a layer of 15# asphalt felt paper, over lapping the seams 4 " and sealed with mastic, as your applying another layer of mastic over that, with another layer of 15# asphalt felt paper spanning the seam below, and also overlapping the seams 4" and sealing with mastic. Now a layer of 6 or 8-mil plastic, with the seams overlapped and sealed with clear packing tape(has a good perm rating)
Now lay your sleepers out on 8" centers and don't use pressure treated, as it has a high moisture content, which will effect the flooring.
http://www.AustinFloorguy.com
Floordude is offline
Old 12-15-2007, 04:57 PM   #26
Jerry T's Avatar
I believe it is dried down to between 15 and 18%. Subfloors or sleepers needs to be down around 9,10,12% range for this use ... whatever the normal moisture level is for your area of the country.
Where I live the norm would be in the 8.5 % to 10.0 % range. I have gone into Lowes and stuck CDX and BCX plywood on the rack and have it read around 10 % MC.
Jerry T is offline
Old 12-15-2007, 05:17 PM   #27
Jerry T's Avatar
This is an except taken from the
AMERICAN LUMBER STANDARD COMMITTEE, INCORPORATED
TREATED WOOD ENFORCEMENT REGULATIONS
October 27, 2006
KDAT - Kiln dried after treatment to a maximum
moisture content of 19 percent for lumber under
5-inch nominal thickness or if 5" or more in nominal
thickness the maximum moisture content may
be specified as provided for in lumber grading
rules certified by the Board of Review.
KD-15 - Indicates lumber that has been kiln dried
to 15% or less moisture content at time of dressing
(appears on grade stamp).
This would pertain to sleepers but the same MC is used for treated plywood I think.
Jerry T is offline
Old 12-15-2007, 06:47 PM   #28
JPhelps's Avatar
I agree under normal circumstances treated ply is too wet to lay on off the rack.....if you had time to let it dry in house before you layed your product that would be great. The guys at the mill where I get my hardwood have offered to let me "stick" the plywood in their kiln to take it down to a more suitable level. Though I have to agree that treated ply probably isn't necessary by the time you've applied the appropriate moisture barriers.
JPhelps is offline
Old 12-15-2007, 07:53 PM   #29
Old school Ranger
floorinstall's Avatar
Trade: flooring
The way I've always done it and NOFMA recommends is the sleeper is glued and nailed to the concrete and the moisture barrier is laid over the top of the sleepers. If you are using 3/4 inch thick hard wood you don't have to put down a plywood sub-floor over the sleeper. To do this you have to install your sleepers 12 inch on center and each flooring strip board must span at least 3 sleeper. The end joints do not have to fall on the sleeper but staggering the end joints at least 12 inches is necessary. I did an American Eagles Outfitters about 7 years ago and there has been no complaints. By not installing plywood over the sleepers you floor elevation is not as dramatic.
floorinstall is offline
Old 12-15-2007, 08:23 PM   #30
They are experts, but I don't get a vapor barrier full of holes.
Not to mention the PITA factor for not having it crawl all over the place while you wrestle the flooring into place.
No problem with nailing ¾" flooring directly to the sleepers, but I think I'll keep my vapor barrier on the bottom, thank you very much.
neolitic is offline
structural concrete... mdshunk Masonry 3 03-05-2009 03:42 PM
flooring over concrete billy0510 Flooring 13 05-19-2007 10:14 AM
Moisture Barrier BKA Concrete & Paving 3 05-16-2007 04:53 PM
Re-claimed Vertical grain fir Flooring Coop Flooring 5 11-13-2005 08:49 PM
How to Install Solid Hardwood Flooring on Concrete Foundation gilamherst Flooring 13 02-05-2005 07:02 PM
