Flooring Direction Relitive To Joists
Old 05-18-2005, 05:35 PM   #1
bergenbldr's Avatar
Trade: builder remodelor
when laying hardwood flooring my understanding is that flooring should be laid at 90 degrees to floor joist.is this required with floating floors also with 3/4"plywood t-g subfloors being much stiffer than boarded subfloors is possible to run nail down floors parallel to joist.
bergenbldr is offline
Old 05-18-2005, 08:14 PM   #2
Repair/Remodeling Tech.
jproffer's Avatar
Trade: Repair and Remodeling Services
Re: Flooring Direction Relitive To Joists
"Floating floors" offer no structural value what-so-ever, so IMHO you can orient it any way you please, 90 deg....in line....diagonal...even standing on edge ...well ok maybe not that last one, but I would say any way that you like the look of it, go for it.
jproffer is offline
Old 05-18-2005, 08:32 PM   #3
bergenbldr's Avatar
thats what i was thinking ,current job may have radiant heat under wood subfloor with floating no worries about nailing thru tubeing runs.
Old 05-18-2005, 08:39 PM   #4
Teetorbilt's Avatar
jp has it right. Don't depend on any 'floating flooring' for structural use, it was never designed for this.
Albert Einstein
Teetorbilt is offline
Old 05-18-2005, 09:08 PM   #5
Flooring Guru
Floorwizard's Avatar
Trade: Sales Manager
I concur
Floorwizard is offline
Old 05-19-2005, 09:35 AM   #6
jproffer's Avatar
BTW Berg,
You do nail "floating" floors, but only on the edges. I.E. - only the first piece and the last peice. <--official comment
Now then, I have done a floor without edge nailing it(due to an abundance of concrete below it...and a lack of tools to do anything about it), and it turned out ok. Still hasn't moved after a couple years. <---unofficial comment
jproffer is offline
Old 05-21-2005, 04:34 PM   #7
bergenbldr's Avatar
Not sure i understand edge nailing floating floor. Isn,t this only done with glue down floors.When i say floating i am refering to clic and edge glued laminate and engineered floors.
Old 05-21-2005, 09:19 PM   #8
Teetorbilt's Avatar
Floating means non-secured.
Albert Einstein
Old 05-22-2005, 10:00 AM   #9
jproffer's Avatar
Floating, in all instructions I've read, means minimally secured (nailed on the edges). But like I said I've done it both ways with no problems.
jproffer is offline
Old 05-22-2005, 12:02 PM   #10
Teetorbilt's Avatar
jp, we must be talking about different systems. The 'floating' flooring that I install requires an open perimeter to allow the product to expand and contract with variations in temp. and humidity. Securing the perimeter would cause the product to buckle or open seams.
Albert Einstein
Old 05-22-2005, 02:09 PM   #11
ccoffer's Avatar
Correct. Floating floor means floating. I have read alot of stuff. I have yet to see any recommendations that involve nailing the primeter of a floating install.
ccoffer is offline
Old 05-23-2005, 12:46 PM   #12
roar's Avatar
I too have never read any floating installation instructions that had the primeter fixed.
roar is offline
Sistering Sagging Floor Joists.... AllGoNoShow Construction 22 02-25-2011 04:37 PM
Framing Roof Joists for Addition when top Plate is not Level personalt Framing 3 07-20-2007 06:52 AM
Hardwood Flooring - First Go at It DecksEtc Flooring 56 10-05-2006 01:41 PM
Question about floating wood flooring zoner11 Flooring 10 01-17-2006 05:04 PM
Re-claimed Vertical grain fir Flooring Coop Flooring 5 11-13-2005 08:49 PM
