Flooring Or Cabinetry First
Old 05-14-2009, 08:21 PM   #21
LRG WoodCrafting
Leo G's Avatar
Re: Flooring Or Cabinetry First
There is no such thing as a flat true floor. Never has been and never will. Well, maybe in an experimental lab, but in a residence - ain't gonna happen. You need to deal with the flow and shim and/or scribe your cabinetry according to the cards you were dealt.
Sawdust Follows Me Everywhere
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is online now
Old 05-14-2009, 09:10 PM   #22
orson's Avatar
Trade: Kitchen & Bath
Originally Posted by Leo G View Post
I always install the cabinets first. I use the universal anti-grav installation brackets and set them up for a 3/4" float. That way, when the flooring guy comes he can just slip the flooring right under the cabinets
Leo I started reading this and actually bought it for 5 seconds before I realized you were kidding. You got me!!
orson is offline
Old 05-14-2009, 09:11 PM   #23
LRG WoodCrafting
Leo G's Avatar
I was hoping I would get a laugh or two outta that.
Carpenter by day.
http://lrgwood.com
Leo G is online now
Old 05-14-2009, 09:24 PM   #24
Builder/Remodeler
ChrWright's Avatar
Trade: Builder/Remodeler
Send a message via Skype™ to ChrWright
Floor first... and then scribe all your cabinets to the floor you lazy bastards...
(and I've seen a GREAT many 'new' houses with floors up and down and all over the place.)
Christopher Wright, CR: President @ WrightWorks, LLC/President @ Central Indiana NARI, Named to the 2010 REMODELING Big50
www.WrightWorks.net - Facebook - Twitter - Carmel Remodeling
Indianapolis Kitchen Remodeling Contractor - You Can Get There From Here
ChrWright is offline
Old 05-14-2009, 09:28 PM   #25
Youngster
Cache's Avatar
Trade: Builder / Consultant / Designer
Even if you have the anti-grav brackets (LOL) flooring first, then cabs. This is new construction we are talking about, so the floor should be level enough. I've never seen a new const. floor that is wavy enough to bother the cabs. Unless the cab guys completely forgot how to scribe the toe kick.
Even in an old rehab you'll want to do floor first and if the subfloor is really non-level, then try to rectify the situation before/during the flooring install. Even if the floor is really out of whack, the cab installers should level the cabs, which for me usually means levelling from the high spot. In a long run I guess it is possible that we are talking more than 1/2" that a shoe mold would handle.
In the end, always floor first. It looks nicer. Kinda the same as undercutting the door jambs for tile. It looks much more professional, and the added bonus is that the install of both cabs and floor is faster that way.
Cache is offline
Old 05-14-2009, 09:37 PM   #26
LRG WoodCrafting
Leo G's Avatar
Can't put shoe molding on these cabs
Carpenter by day.
http://lrgwood.com
Leo G is online now
Old 05-14-2009, 09:42 PM   #27
Youngster
Cache's Avatar
Most of mine are like that actually, some with furniture feet. Scribes for those of course.
Cache is offline
Old 05-14-2009, 10:14 PM   #28
Teetorbilt's Avatar
Floor first.
A kitchen is going to be wet from spills, etc. At some point something major is going to happen (faucet/connection/valve, drain, icemaker, dishwasher, InstaHot....).
If the cabs are below floor level they will be sitting in a well of water that cannot be reached. Even solid hardwood cabs are going to swell under this condition and particleboard is completely gone.
Albert Einstein
Teetorbilt is offline
Old 05-14-2009, 10:52 PM   #29
Knowledge Factory
Floordude's Avatar
Had an inspection of a buckled wood floor. The cabinets were set on the wood floor.
One of a kind stone slab tops.
Broke the tops on two counters across from each other, and the center island, and jacking the custom cabinets, where they were firewood.
Couple of hundred floor repair, turned into a $50,000 mistake.
http://www.AustinFloorguy.com
Floordude is offline
Old 05-15-2009, 09:14 AM   #30
JonM's Avatar
Originally Posted by loneframer View Post
What if you want to keep the floor and change the cabinet layout?
Your wife will make you change the floor also...
JonM is offline
Old 05-15-2009, 10:50 AM   #31
ian @antex western
ian@prosource's Avatar
Trade: flooring
from a flooring view point i would put the floor down first, if i was a kitchen fitter i would say put the cabs in first,
However i have seen jobs with cabs in first and then they have problems getting dishwashers in under the worktop due to the step that is caused by the height of the floor finished at the foot of the cabs, also i have seen jobs where the cabs & machines where in first and once the floor was fitted the machines could not be pulled out without taking the worktop off,
'what comes first, the chicken or the egg'
ian@prosource is offline
Old 05-15-2009, 11:45 AM   #32
Builder/Remodeler
ChrWright's Avatar
What you describe is just bad planning. If the cabinets go in first--you cleat and level them to the height of the finished floor and run your flooring under the appliances.
A poor craftsman is going to make a soup sandwich of it either way.
Old 05-15-2009, 05:53 PM   #33
ian @antex western
Trade: flooring
as i said, i have seen jobs like this, not done them myself,
The temp rental i am in at the moment has laminate fitted, we tried to pull the dishwaher out to get to the supply behind, could not tilt it back enough to get the machine out over the edge of the laminate,
my guess is they got what they paid for when it was installed, doh
Old 05-15-2009, 05:57 PM   #34
KemoSabe
loneframer's Avatar
That's when you keep the floor and the cabinets and dispose of the wife.
loneframer is offline
The Following 2 Users Say Thank You to loneframer For This Useful Post:
Floordude (05-15-2009), greg24k (08-13-2010)
Old 05-21-2009, 10:24 PM   #35
Casap CEO
mrwoodman's Avatar
Trade: Contractor Membership Service
A lot of good replies on this issue other than the tile guy and the plywood under the cabs. Doing the plywood only increases the odds of "NO EXPANSION" if installing the woodfloor to close and I have some other issues with that too. There's my 2cents.
Ron T
mrwoodman is offline
Old 05-27-2009, 08:50 PM   #36
user3321's Avatar
Trade: no
Flooring first always. If the customer ever decides to change the layout of the kitchen, they won't have to change the flooring if they don't want to.
user3321 is offline
Old 05-28-2009, 07:45 AM   #37
BKM Resilient's Avatar
Trade: Flooring
My grandfather's home was I-beam construction. State of the art in the Pittsburgh area when that was still one of the world's booming economies. You never saw floors, doors and windows so flat, level and plumb in your life. The foundation work is awesome and the total square footage is well over 5000 square feet but that includes a large 1/2 unfinished basement. The local builder built the home for his own family with a custom designer----- all the best materials using all his top men . The house is well over 50 years old and every door and window open and close perfectly true as if the work were just completed yesterday.
IT CAN BE DONE!!!!!
BKM Resilient is offline
Old 05-28-2009, 08:45 AM   #38
LRG WoodCrafting
Leo G's Avatar
There is no such thing as a flat, true floor, no sheetrock wall is perfectly flat. Real close with strict attention and steel studs, sure. Perfect, nope.
So when the cabinetry was put in the house, not one shim was used?
Carpenter by day.
http://lrgwood.com
Leo G is online now
Old 05-28-2009, 11:28 AM   #39
Cabinetmaker
skymaster's Avatar
Trade: Cabinetmaker
Send a message via AIM to skymaster
floor,floor floor; If not then you will have a nightmare with the dishwasher and any other under the counter appliances.
skymaster is offline
Old 05-28-2009, 12:26 PM   #40
Flooring Guru
Floorwizard's Avatar
Trade: Sales Manager
there are plenty of good reasons to install floor first.
this is not one of them.
Floorwizard is offline
Tags
www.waldenhatton.com
laminate flooring placement nwksremodeler Flooring 7 06-19-2009 10:24 AM
need some flooring suggestions Farmer Boy Flooring 4 02-21-2009 07:53 PM
Brazilian Walnut nail down flooring Monrovi Flooring 12 01-01-2009 10:13 AM
Cork Flooring Questions.... SBI Flooring 3 12-12-2008 04:18 PM
Re-claimed Vertical grain fir Flooring Coop Flooring 5 11-13-2005 08:49 PM
