Trade: finish and trim
Flooring Or Cabinetry First
I have a new home to install true hardwood flooring in the kitchen dining area. I also will be setting the kitchen cabinets. I have asked a handful of people wich is better or the norm, to put in all the flooring and then come back and set the cabinets on top of it or set the cabinets and cut the flooring in around them. This is a first for me because I usually install flooring of this nature on a remodel or up grade and I have to cut in around every thing, unedrcut door jambs etc. I was thinking that putting in all the flooring would save me time and hassles. I would not have to put spacers under my base cabs to bring them up the thickness of the flooring, Would not have to put base shoe around every thing, and would save a ton of cut in time. what do the pros think. safe enough or bad idea?
strat hd
Trade: framing contractor , remodeler , GC occasionally
Re: Flooring Or Cabinetry First
Floor first.
solar guy
Trade: solar contracting
In my op if you are doing a natural finish sand and finish in place flooring,I would do the flooring first, sand , seal ,set cabinets, fiber disk and finish.
This makes it easier than sanding around cabinets with all the edging etc. Prefinished is a slightly different story. If you are careful and protect the flooring as all the other stuff is going on it works out ok. If you have animals working in there maybe it would be better to wait. Wit exotic hardwoods I have always waited but built up cabinets for the thickness of the flooring. |
egotistical prick
Trade: Wood Inlay
Flooring first.
Flooring first. And you could go one step further. Put 3/4 ply under the cabinets instead of wasting flooring.
You run into height problems when you put flooring in first.
strat hd
Measure out to where the cabs. are going to sit. Snap a line. Run flooring past the line an inch or so. Set cabs on flooring. Shim under back and sides of cabs.
| The Following User Says Thank You to strathd For This Useful Post: | the big 12 inch (05-14-2009) |
#1 stunner
I always do floor first.
Flooring Guru
Trade: Sales Manager
floor first is usually the best option.
No base shoe usually needed appliances fit nice easier for the installer only down side.....cabinet guys install on fresh new undamaged hardwood. but there are ways to protect it. Best to take a few pictures of the floor before they arrive and have the cab guys look at the floor too and agree to the condition. then look at the floor before they leave to look for dents or scratches that are unacceptable that way it eliminates the pissing match
------------------------ "in 20 years you will regret more what you did not do than what you did" |
LRG WoodCrafting
I always install the cabinets first. I use the universal anti-grav installation brackets and set them up for a 3/4" float. That way, when the flooring guy comes he can just slip the flooring right under the cabinets
![]() Floor first whenever possible. Unless you know it is the last kitchen the HO will ever install, put the entire floor down, don't cheat by skipping under the cabinets. Unless, the flooring is hard to come by with limited availability or really pricey. Do them a favor and lay the whole space.
Cabinets first...if you ever want to change the floor or need to do a repair you will be glad you did...
#11 | |
Flooring Guru
Re: Flooring Or Cabinetry FirstQuote:
You do have a point that changing out later would be easier...however why would someone buy a product like wood with the intent to replace..... in other words...you have a good point...but other points would overide that one. It shouldn't be the overiding factor in the decision.
Thom
Floor First BUT I'm not a fan of wood in the kitchen. Tile it.
Flooring Guru
Tile doesn't work for everyone.
works for water but not for the elderly or people who have leg problems. Doesn't do too well for people with kids ready to learn to walk either.... But it is the best surface all around for durability and moisture issues no doubt about that
#14 | |
Craig Arnold
Trade: Granite,Marble,Ceramic Tile
| The Following User Says Thank You to Longghairr For This Useful Post: | JumboJack (05-14-2009) |
Flooring Guru
If it's a floating floor, then it's a non issue....cabs first. Unless you are mounting the cabs to the walls.
But a nail down floor still needs it to be level...and flat mostly. I don't belive I have seen a floor that is unacceptable for cab install but fine for nail down wood.
#16 | |
strat hd
True hardwood floors ! And some of you guys are saying do it this way so remodeling will be easier ? |
| The Following User Says Thank You to strathd For This Useful Post: | MarcD (12-17-2009) |
Flooring Guru
This is really standard for this type of question.
10 years and I see the same answers... 10 years from now we will see the same answers.... such is life....
#18 |
KemoSabe
I prefer flooring first, that being said, you will have less than perfect floors for a variety of reasons. I have rarely seen a perfectly level foundation, or perfectly milled lumber, or floor joists that stabilize at the same dimension. Decking has a tendancy to washboard between joists, even when spaced properly if it sees enough inclement weather. Lumber changes with humidity, so if it's perfectly level today, it may not be down the road. Crowning in boards will vary also. Even engineered lumber will deflect at different rates according to loading, thats why I do X bridging no matter what. Point loads will compress decking and blocking unless it is isolated from the floor as in a steel column. Center girders will shrink in dimension unless engineered lumber or steel is used.
The point I'm making is, you have to deal with all the curves that are thrown at you. If the floor going down is being site finished I would install it first to limit the obvious risk to cabinets. If prefinished is going down, I may want to install cabinets first. Asess the risks, make a calculated decision and move forward. It's been done both ways and niether is right or wrong.
__________________________________ "Walking the fine line between production and perfection" __________________________________ |
#19 | |
KemoSabe
| Tags |
www.waldenhatton.com ![]() |
| laminate flooring placement | nwksremodeler | Flooring | 7 | 06-19-2009 10:24 AM |
| need some flooring suggestions | Farmer Boy | Flooring | 4 | 02-21-2009 07:53 PM |
| Brazilian Walnut nail down flooring | Monrovi | Flooring | 12 | 01-01-2009 10:13 AM |
| Cork Flooring Questions.... | SBI | Flooring | 3 | 12-12-2008 04:18 PM |
| Re-claimed Vertical grain fir Flooring | Coop | Flooring | 5 | 11-13-2005 08:49 PM |
