Floor Prep Questions
Old 12-01-2005, 06:26 PM   #1
Robie's Avatar
I'm underway on my second tile job.This is a concrete slab in a family room. The floor has 3-4 feet of 6" ceramic tiles around the perimeter with 6" wooden parquet tiles in the middle (165 sq. ft.)
I took off the parquet today with a cold chisel and that went pretty well. I'll be installing 12" ceramic tiles in place of the parquet on the diagonal.
I'm wondering about the adhesive used for the parquet. Should a floor scraper be sufficient to get the old adhesive up or should I spend $60/gal. for adhesive remover? Bottom line...does the concrete have to be perfectly clean of old adhesive before continuing? I'm planning on a 3/8" notched trowel.
Also, what Thinset would you recommend?
Any other helpful tips and ideas are most appreciated.
Thanks.
Rob
If you have integrity, nothing else matters. If you don't have integrity, nothing else matters. ~Alan Simpson
Robie is online now
Old 12-01-2005, 07:52 PM   #2
Suck it up, or shut up
rservices's Avatar
Re: Floor Prep Questions
I'm sure their are plenty of pro's here but, check out john bridges tile forum great help
rservices is offline
Old 12-01-2005, 09:35 PM   #3
ccoffer's Avatar
Believe it or not, the fastest way to get the stuff up is with a 4 inch Personna wall scraper. Being right down on the floor will give you a degree of leverage you cannot get with a standing scraper. With only 165 feet to clean up, you should be able to get the area clean as a whistle in less than thirty minutes.
Removers are more trouble and time than they are worth for small projects.
As far as which thinset to use, you might as well just buy the cheap unmodified stuff. As long as you get 100 percent coverage, you will be fine. Many folks cling to the notion that thinsets with dry-spray polymers are necessary to ensure the bond strength required. It is a false notion.
Durabond D-5 is as good as any. If you have an insatiable desire to use modified stuff, just buy a bottle of additive and mix it with the D-5.(or equivalent)
ccoffer is offline
Old 12-01-2005, 10:05 PM   #4
Flooring Guru
Floorwizard's Avatar
Trade: Sales Manager
Don't forget an anti-fracture membrane before the tile.
Floorwizard is offline
Old 12-02-2005, 06:50 PM   #5
Robie's Avatar
What a nightmare!
I started out this morning with the 4" scraper and a new pack of blades. This stuff will not budge. About all I was able to do was get the ridge off the adhesive left from the notched trowel. After about 3 hours of both the scraper and a sharpened floor scraper, I decided it was time for the adhesive remover. I think spit would have done just as well, without the mess. I "experimented" on about 30 sq. ft. and most of the adhesive is still intact after 2 applications. I've spent all day and am still no further ahead. I cleaned up my mess and came home.
I'm assuming the next step is a sander. I tried my belt sander with 80 grit and that didn't touch it. What kind of sander do I rent, paper grit, etc and what kind of a mess is this going to make? Of course the house is filled with crystal and antiques!!!
Again, thanks!
Rob
Robie is online now
Old 12-02-2005, 08:19 PM   #6
Donedat's Avatar
Trade: Hardwood Flooring
Send a message via MSN to Donedat
Since your sanding glue off of concrete, just one of the tilt-style floor sanders with the roughest grit they'll sell ya. Just ask for a drum sander for hardwood floors. The rentals usually work well for sanding glue.
I admit...I don't know everything...but don't tell my kids I told you.
Donedat is offline
Old 12-04-2005, 11:22 PM   #7
adams,b's Avatar
Trade: hardwood floors
If it is like what you are saying, just Hard disc it with 20 grit vaccum it up and go with it. Or you could milk it or prime it and float over the entire floor. Either way, you dont want any specs that will touch the bottom side of your tile when you set it.
adams,b is offline
Old 12-06-2005, 11:16 PM   #8
Robie's Avatar
Rented a sander...useless. Got ahold of a floor grinder with carbide blades. No more glue.
Robie is online now
Lots of questions about drywall and bathrooms nobody Drywall 30 11-27-2008 01:33 PM
Few questions for a Handyman or Contractor in VA ButlerDesigns Business 5 05-22-2008 12:12 PM
I'm new and i have questions... Jadzu General Discussion 2 08-25-2006 07:03 AM
Qualifing Questions For Customers dfwhomeremodele Marketing & Sales 19 03-22-2006 01:15 PM
