Floating Or Glued?
Old 11-26-2005, 11:04 AM   #1
ChuckEA's Avatar
Trade: handyman
Floating Or Glued?
I have a prospective client that wants to put pre-finished solid oak over a concrete slab. The product they selected is 5/8" thick and measures 3" wide. The strips are grooved on the bottom to accept locking clips. What method would you recommend for installation. I was thinking a floating install but want to make sure that we don't get a hollow sound. What underlaymnet would help deaden the sound and provide a vapor barrier? The supplier, Floor n Decor, has a couple of products -- the first is like a felt with a thin poly sheet on top and is called "Silent Stride"; the second is more like a rubber foam mat and is called "Sound Solution" We are located in Atlanata area so humidity is a consideration. Appreciate any guidance you guys can provide?
ChuckEA is offline
Old 11-26-2005, 01:18 PM   #2
Donedat's Avatar
Trade: Hardwood Flooring
Send a message via MSN to Donedat
Re: Floating Or Glued?
Hi,
I'll tell you what I always do when I come across a new product. I go to their web-site and look for their own installation instructions. Then, I call their tech office to ask questions that may not have been covered in their written instructions. Then, after all that, if I want to deviate from those written instructions I ask myself, "Am I willing to warranty this installation?".
Well, that's it. That's my secret. Not sure about the sound proofing, but I'm sure the manufacturer will have some suggestions for you. Bottom line is anything you do contrary to those written instructions voids the warranty.
I admit...I don't know everything...but don't tell my kids I told you.
Donedat is offline
Old 11-26-2005, 01:21 PM   #3
ccoffer's Avatar
Sound solution is a good product to float over. Their warranty is iron clad. I am assuming you are talking about Junkers. That is the only one I know of with the clip doo-dads. By floating and using Sound Solution (do NOT use that other crap) you trump any moisture issues provided you run it up the walls a little.
Is this below grade? If so, you probably cant go with a solid. I work the Atlanta area myself and I am quite familiar with the wide swings in EMC we get around here.
ccoffer is offline
Old 11-26-2005, 03:18 PM   #4
Flooring Guru
Floorwizard's Avatar
Trade: Sales Manager
Float over a vapor barrier.
If you glue down, bostic's best is the only I have heard of that would warranty. But I still would not do it.
I would rather use cork underlay and float over it. Best to check with manufacturer on this.
Floorwizard is offline
Replacing Piece of Laminate on Floating Floor Spencer Flooring 13 12-06-2008 08:40 AM
Glued down carpet puller Marizzaldi MFG Tools & Equipment 4 03-14-2007 12:17 AM
Removal of glued down carpet over oak floor SPEEDSQUARE Flooring 6 01-07-2007 06:54 PM
floating floor MarcM8181 Flooring 3 11-04-2006 03:26 PM
Question about floating wood flooring zoner11 Flooring 10 01-17-2006 05:04 PM
