Trade: Lisc. General Contractor
Expansion Gap On Laminate Flooring
I put down snap together floating laminate in my church fellowship hall (40'x60') and left at least 1/4" just like the directions said on the box once it got hot it started to rise swell up took the shoe moulding up and it was against the wall anybody got any experience putting laminate hardwood on concrete floors in big rooms? I went around and cut another 1/4" off the edged do you think it is going to pull out when it gets cold? I guess the were not figuring on 60' runs when they sail 1/4" for expansion. thanks
Re: Expansion Gap On Laminate Flooring
You shouldn't have any more problems. Did you acclimate it prior to installation? 40 X 60 is a pretty good stretch without transitions.
I like Pergo in the high-end stuff and have never had any problems here. Our humidity is from about 50-100%. It's the ratio that counts.
"da Whale don't hesitate"
Trade: Hard Surface Flooring
Thats exactly why they tell you to not go over a 30ft continuous run or iirc 1000sf of area without a t-molding. That being said I have done several without any problems just by allowing for more expansion space. teetor also brings up a good point about acclimation...its not just a suggestion, its required.
Precision Flooring (772) 237-9900 Tile, Hardwood, Laminate, and Resilient Installation, Sales & Repair - "We do it right the FIRST time" |
this was the low end stuff $.89 they didn't say anything about long runs on the directions how much are you guys getting a square foot to put down floating laminate.
Flooring Guru
Trade: Sales Manager
Sounds like pretty unstable stuff.
------------------------ "in 20 years you will regret more what you did not do than what you did" |
Furniture? What kind of prep work? Moldings supplied or am I staining to match? Takeup? Without knowing all of that (and more) its hard to answer "how much". Every job is different and therefore gets bid differently. I guess you could say 2 bucks a foot for a bare bones install would be a good starting point ( for my market).
#7 | |
Re: Expansion Gap On Laminate FlooringQuote:
#8 | |
TURNER FLOORING
Trade: Floor installation
When it comes to cheap materials..He said it right. you get what you pay for. And that's so true in all cases that i've dealt with..Next time cover yourself with the sign off or something to explain why the floor has problems other than a bad install. Sometimes it's not your fault, but trust me they will blame you unless you cover all your bases. Let others make crucial decisions so you aren't the fall guy. Especially when it's a cheap floor.. It's bound to have something go wrong. It's cheap.. and for a reason..
http://TURNERFLOORING2.com http://www.TURNERFLOORING.com/ Flooring the world over... Last edited by turner flooring; 03-02-2007 at 01:37 AM. |
| laminate flooring | imik | Flooring | 5 | 01-12-2008 01:39 PM |
| Air Bubbles in Laminate Flooring | Bigman | Flooring | 19 | 09-05-2007 10:07 PM |
| Removing a small section of laminate flooring | MKamis | Flooring | 3 | 07-30-2007 06:02 PM |
| What Blade do you use for Laminate Flooring? | dayspring | Tools & Equipment | 8 | 01-21-2007 02:04 PM |
| Miter Joints In Laminate Flooring ?? | AL MURZYN | Flooring | 6 | 12-27-2006 10:15 PM |
