"Epoxy Covering" - Flooring - Contractor Talk
"Epoxy Covering"
Old 08-17-2007, 06:48 AM   #1
What stop sign?
ODDBALLS's Avatar
Trade: Home Remodel, repair, and maintenance.
Rewards Points: 150
"Epoxy Covering"
I think I already know the answer to this but want to double check. I have a job that is converting a already converted garage to a art studio. The customer wants to use Behr 1-part epoxy floor paint (she found at the The Home Depot). My question is, is it worth a hoot? If not what do you suggest? She wants something that will just be durable and easy to wipe paint off of. It is about 300 sq ft. Thanks.
ODDBALLS is offline
Old 08-17-2007, 09:36 PM   #2
Doer of Many Things!!!
gideond's Avatar
Trade: Paint and Floor Covering Retailer
Rewards Points: 1,135
Re: "Epoxy Covering"
No. Avoid anything with the Behr name on it. If you want a decent one part try SealKrete or Richards. I've used both and they work pretty well provided you aren't expecting too much out of a one part epoxy modded acrylic. I've seen a couple cases of the Behr, both of which have horrendous lap marks.
gideond is offline
Old 08-21-2007, 01:23 AM   #3
What stop sign?
ODDBALLS's Avatar
Rewards Points: 150
Or, does any one make a good, basic conctete floor paint?
ODDBALLS is offline
Old 08-21-2007, 05:48 AM   #4
gideond's Avatar
SealKrete and Richards both have very good one part epoxy modded acrylics. Most paint companies will have their own floor paints as well. These are generally oil or acrylic with a urethane built in to them to give them added hardness. If you are going water based I still use the epoxy modded products. They are harder than a standard acrylic floor paint.
gideond is offline
