Epoxy
Old 10-15-2008, 07:29 AM   #1
sbeck's Avatar
Trade: flooring installer
Epoxy
whats the best way to remove epoxy paint from a concrete floor
sbeck is offline
Old 10-15-2008, 07:59 AM   #2
Money Changer
bert0168's Avatar
Trade: Residential Remodeling
Re: Epoxy
Probably best to ask a certified flooring installer
bert0168 is offline
Old 10-15-2008, 08:20 AM   #3
Handle It!
MALCO.New.York's Avatar
Re: Epoxy
What are you? A Damn Plumber now?
Ultimate Wisdom---------
MALCO.New.York is offline
Old 10-15-2008, 08:22 AM   #4
Handle It!
Re: Epoxy
I could be wrong.......But I recall that MEK (Methyl Ethyl Ketone) will do the trick.
Old 10-15-2008, 03:02 PM   #5
Money Changer
bert0168's Avatar
Re: Epoxy
Nah, just trying to start my day off right!!
bert0168 is offline
Old 10-19-2008, 10:23 PM   #6
S-C-Coatings's Avatar
Trade: Custom Floor Coatings and Spary In Truck Bed Liners
Re: Epoxy
First you should determine the thickness of the Epoxy coating and what brand. If it is the stuff you can buy at the major home improvement centers, then they are a little easier to get off. If you find just a thin layer, it can be removed with some sanding and a solvent, try MEK or some All Solve. Make sure you have ventilation. If it is a little thicker you may want to rent a floor grinder / sander.
What are you planning on doing with the floor after the epoxy is removed?
If you are re-coating it, you may be able to get away with just acid etching and light sanding. Hope this helps.
S-C-Coatings is offline
Old 10-19-2008, 11:53 PM   #7
Knowledge Factory
Floordude's Avatar
Re: Epoxy
If your planning on adhering something or repainting, you may not want to use chemicals, as they can hinder the bond of the new adhesive used.
With that said, Google "SoyGel"
If your going to glue or coat it, you might want to look into bead blasting. It is a walk behind machine, that look like a huge vacuum.
http://www.AustinFloorguy.com
Floordude is offline
Old 10-20-2008, 04:45 AM   #8
celtic
Taranis's Avatar
Trade: Flooring
Re: Epoxy
Simple,
use a diamond planer with vacuum attachment to remove the paint. What make it is doesn't matter. The heavier the coat the longer it will take to come off, self explanatory I suppose but there you are.
Using a chemical may not just affect the bond but if there is any residue can affect the new resin if you are putting one down.
Taranis is offline
Epoxy floor paints rservices Painting & Finish Work 1 09-15-2008 11:53 AM
Epoxy Garage Floors RoSSco Painting & Finish Work 8 09-04-2008 11:00 AM
Portland or Epoxy grout? Ponsse Ceramic & Stone Tile 10 04-14-2008 08:53 AM
Epoxy On Tile go do it Ceramic & Stone Tile 14 05-16-2007 09:10 PM
Epoxy garage floors gschwoyer Painting & Finish Work 3 02-23-2007 09:36 AM
