Engineered Wood On Stairs - Flooring - Contractor Talk
Old 02-15-2018, 12:14 PM   #1
90%-er
onmywayup's Avatar
Rewards Points: 1,606
Just laid in 1200 Sq ft of glue down engineered wood at this house. Stairs were originally going to be carpeted, but homeowner is requesting I put the same wood on the stairs. He has ordered some bullnose pieces for the noses of the runs, but I'm wondering if I have the right idea about the rises.
Planning to install filler material on each rise to pack out the area that the current tread nose hangs over, glue my flooring to the rises, then recreate the noses of the treads using the new bullnose pieces.
Does that work? I don't believe I've ever had to put hardwood or anything but carpet on a stairway.
onmywayup is online now
Old 02-15-2018, 03:19 PM   #2
Particulate Filter
Metro M & L's Avatar
Trade: Flooring
Rewards Points: 1,356
Re: Engineered Wood On Stairs
Overlay bullnoses on treads look like crap and theyre a trip hazard. They also collect debris like crazy.
Why not just install real wood treads. They're like 36$ a piece. You bill for install and sand and finish. You can do the finishing with a 60$ palm sander. Prefinish them. Install and then buff and coat once in place. Color matched wax filler for nail holes.
If there isn't room for a 1/2 inch or 3/4 solid riser I use 1/4 veneered plywood in the appropriate material. Glue it up and a couple pins to hold it in place.
Metro M & L is offline
The Following User Says Thank You to Metro M & L For This Useful Post:
asevereid (02-15-2018)
Old 02-24-2018, 07:36 AM   #3
90%-er
onmywayup's Avatar
I disagree that it looks like crap. Here is how it turned out
Old 02-24-2018, 08:31 AM   #4
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 13,728
Not bad, but the overlayed bullnose does look like crap.
Inner10 is offline
heavy_d (02-24-2018)
Old 02-24-2018, 10:09 AM   #5
I like Green things
WarnerConstInc.'s Avatar
Rewards Points: 4,702
Yeah, it looks like crap. Good work, but visually ugly.
Warner Mill Works
Facebook
YouTube
WarnerConstInc. is online now
pinwheel (02-24-2018)
Old 02-24-2018, 11:24 AM   #6
90%-er
onmywayup's Avatar
At least lube it up before you shove it in, fellas.
Old 02-24-2018, 11:27 AM   #7
Railman's Avatar
Trade: Railing
Rewards Points: 459
Glad it worked out for you, & work looks fine, but......
It really needs skirt boards. They needed to be done before the treads. The dark stain really makes it worse than if it were a lighter carpet.
Btw...
How in the world did they end up with a door swinging over the stair?!!!
Railman is offline
Old 02-24-2018, 04:35 PM   #8
90%-er
onmywayup's Avatar
Btw...
That door is super dangerous, but they realize it. The house is full of evidence that the last owner THOUGHT himself to be quite the diy-guy.
I know what the logic was because it is a narrow hallway above the stairs, but it is super stupid.
The Following User Says Thank You to onmywayup For This Useful Post:
Engineered wood glue residue Atomm Flooring 16 07-01-2016 04:48 PM
Underlayment for Engineered Wood Floor CCSERV Flooring 9 12-31-2012 01:52 AM
Warped engineered wood. Jackpine Savage Flooring 5 05-20-2012 10:32 AM
Engineered Wood Cache Flooring 1 04-08-2011 09:23 AM
Glue and staple engineered wood on stair treads? cej22 Flooring 1 09-23-2009 09:59 AM
