Engineered Wood Flooring Installation
Old 07-30-2007, 08:34 PM   #1
graart's Avatar
Trade: general
I'll be installing engineered wood glue-down flooring. Would you guys put 1/4 in BC plywood on the top of the existing subfloor OSB (coverd by carpet now), or go directly to OSB?
If 1/4 in plywood: would you screw it to OSB or glue and screw?
Thanks for your expertise.
graart is offline
Old 07-30-2007, 08:54 PM   #2
Professional Installation
Demal's Avatar
Trade: Flooring
Re: Engineered Wood Flooring Installation
If you added under layment, what would that do to the rest of the house? Are there any areas that the new floor is going to touch?
Demal is offline
Old 07-30-2007, 09:10 PM   #3
graart's Avatar
Trade: general
The new floor will be in an addition ( new subfloor OSB) and the rest od the downstairs will be at the same level after the carpet is removed.
graart is offline
Old 07-31-2007, 07:21 AM   #4
Mike Costello's Avatar
Trade: Flooring
Send a message via Yahoo to Mike Costello
OSB=Oriented strand board. Height be damned you need to put a subfloor down.
There is nothing that I know of that will warantee over OSB.
I wouldnt even glue carpet to it.
Mike Costello is offline
Old 07-31-2007, 07:40 AM   #5
Trade: Flooring
If you have any doubt , take one strip of the flooring and glue it to the floor, go back tomorrow and yank it up, youll see the top layer of veneer stuck to the bottom of your plank
Old 08-01-2007, 01:56 AM   #6
THE FINISHER
lawndart's Avatar
Trade: Finish Carpenter
Send a message via AIM to lawndart
Mike Costello is correct. OSB is not a good subfloor for flooring installations. May I ask why you are gluing down your hardwood floors? Is this area below grade?
lawndart is offline
Old 08-01-2007, 10:45 PM   #7
graart's Avatar
Trade: general
The instructions for this particular engineered flooring (TraficMaster from Home Depot) says that it is a gluedown flooring. I think I need to follow instructions (??)
I was thinking about putting a 1/4 inch BC plywood underlayment on the OSB subfloor. QUESTION: should i glue it or screw it (or both) to the OSB?
thanks in advance for your advice!
graart is offline
Old 08-02-2007, 06:27 AM   #8
Trade: Flooring
I always thought Trafficmaster was a laminate product?
If its a true engineered hardwood it can be glued or nailed. As I pointed out before, you wont be able to glue it over osb so if your gonna glue you'll need the subfloor. I install my subfloors with 1 1/2" long 1/4 " crown staples. Every 4 inches in the field and every 2 on the seams.
Ive had bad luck with screws due to the heads popping off and for the same reason as the hardwood you wont be able to glue onto the osb
Old 08-02-2007, 06:35 AM   #9
framing/millwork supplier
dvon104's Avatar
Trade: interior & exterior trim, window and door installs
What about a 1/4" luan ?...do not Know ...just asking ...some of the flooring guy's here use that ...but I sell 2x4's not flooring ...just wanted to pipe in
dvon104 is offline
Old 08-02-2007, 11:10 AM   #10
Angus
Angus's Avatar
Trade: Owner: Flooring Store
Luan is not an accepted underlayment for any flooring. Use a 1/4" plywood underlayment. Nail it with ring shanked nails, or better yet, screws. Traffic master is garbage. For a little more money, try the engineered flooring from Bruce's. Much better quality, and much nicer finished product. Shaw and Mohawk also have good products.
Angus is offline
Old 08-07-2007, 08:52 PM   #11
graart's Avatar
Trade: general
Thanks you all for your advice! I'm returning the Traficmaster and will get 3/4 inch planks for nailing.
graart is offline
Engineered Floor Installation BoydS Flooring 4 02-17-2007 07:18 PM
Laminate Wood Flooring Over An Old Garage Floor mjm0073 Flooring 1 01-30-2007 10:42 PM
Removing Tile over hard wood flooring CMSuper Flooring 10 04-28-2006 10:43 AM
i need work ! wood flooring installer woodfloors Help Wanted or Looking For Work 1 01-30-2006 08:12 PM
Question about floating wood flooring zoner11 Flooring 10 01-17-2006 05:04 PM
