Engineered Hardwood Glue Down Repair…
Old 07-28-2008, 01:00 PM   #1
Thomas Tile
CTT Floor Cover's Avatar
Trade: Floor Coverings
Question
I have been in tile for years, but I have recently started doing wood. Mainly small jobs, but I have been getting a lot of calls about repairs. I would like to start doing repairs, because there doesn't seem to be many people who do repairs. Does anyone have any input about repairs for glue down.
CTT Floor Cover is offline
Old 07-28-2008, 11:10 PM   #2
Poo Flooman
Poor Floorman's Avatar
Trade: C-15 flooring
Re: Engineered Hardwood Glue Down Repair…
Not allot of money in repair work, usually T&M.
You can use repair work to promote your business, like advertising.
Most of the floors you're repairing generally are installation related. Leading to and promoting the disease in the industry, sub standard installations. The yobers installing these sub standard installations couldn't even do a good install, you think they could actually correct one not even being able to do it right the first time?
It takes a qualified installer to get it right the first time, it takes a experienced qualified installer, that is also a floor mechanic to fix one.
Good luck to you.
If you have any questions leave your email, and I'll get back to you.
Poor Floorman is offline
Old 09-21-2008, 03:16 AM   #3
dokuhaku's Avatar
Trade: floorcovering
After removing the damaged plank, be sure to remove every micron of debris/ glue/ wood chunks from the area. It is time consuming but worth the time spent. Once you have applied fresh glue, an errant piece of wood in the groove, for example, can ruin your whole day.
dokuhaku is offline
Hardwood to concrete floor, with nothing in between?? SBI Flooring 7 08-01-2008 02:21 PM
Glue Down Hardwood. cambiumco Flooring 15 01-12-2008 01:05 AM
thoughts on engineered hardwood importer Flooring 15 10-26-2007 05:09 PM
engineered hardwood wildeman Flooring 5 10-06-2006 08:06 AM
Hardwood Flooring - First Go at It DecksEtc Flooring 56 10-05-2006 01:41 PM
