Engineered Flooring Problem
Old 03-01-2009, 09:47 AM   #41
the big 12 inch's Avatar
Trade: hardwood floor contractor 28 yrs.
Re: Engineered Flooring Problem
I still say there will be issues on this job in short order!!!JMO..
the big 12 inch is offline
Old 03-01-2009, 08:29 PM   #42
Knowledge Factory
Floordude's Avatar
I have inspected a few, using that neoprene rubber underlayment.
Bad ju-ju, right there! Covering it up like that creates rH build up under that. like Jerry said, Greenhouseing.
I bet when it's uncovered, there is going to be peaked end joints if that is an engineered. If it is a thick saw wear layer, it will see cupping.
http://www.AustinFloorguy.com
Floordude is offline
Old 03-02-2009, 03:16 AM   #43
mrghm's Avatar
Trade: Commerical Construction
The floors are uncovered at the end of the day, & it allows air to flow over the floor during the night.
mrghm is offline
Old 03-02-2009, 05:18 AM   #44
Jerry T's Avatar
Trade: Self employed - hard surface installer
Carry on mate
Jerry T is offline
Old 03-03-2009, 12:51 AM   #45
William Mear's Avatar
Trade: Contractor
I have tried many a challange but I would not touch that job with a 20 foot pole. I was using BB gluing solids 10 years ago catching all kinds of flack from others but there is noway I am touching this job. Good luck
hey P how was hunting season. hope all is well with you and yourslol
William Mear is offline
Brazillian Walnut(ironwood) Flooring RR/builders General Discussion 5 12-20-2008 10:26 PM
Paint problem Static Design Painting & Finish Work 7 12-09-2008 10:03 PM
Need some help diagnosing & fixing gas furnace problem. whiterabbitva HVAC 12 11-15-2008 10:13 AM
Bosch 12 dual mitre saw, transport lock wont hold? commen problem? woodworkbykirk Tools & Equipment 10 10-28-2008 09:18 PM
General flooring issues Atricaudatus Flooring 3 05-29-2006 04:10 PM
