Elevator Flooring??
Old 12-26-2010, 07:30 PM   #1
Interior Remodeling
Eric K's Avatar
Trade: Interior Remodeling
Rewards Points: 570
Elevator Flooring??
Does anyone have any ideas for a good durable flooring solution for a cargo elevator that doubles as a tenant elevator in an upper scale complex. Currently there is ceramic tile. The tile is cracked at the doors from them pushing trash containers (200-300 lbs) across. Looking for ideas that could replace the tile and add durability but have a good appearance.
Eric K is offline
Old 12-26-2010, 07:49 PM   #2
Project Superintendent
mudpad's Avatar
Rewards Points: 2,000
Re: Elevator Flooring??
Rubber tile works well, and is easily replaced if installed with pressure sensitive glue, or no glue. I have installed it in elevators as well as gyms/ exercise rooms.
As you probably know, you have to be careful about adding weight in an elevator, but if you already have ceramic tile you probably are not going to have anything heavier.
Steve
mudpad is offline
Old 12-26-2010, 10:31 PM   #3
Carbon Dioxide Producer
DuMass's Avatar
Trade: EC
Since itís an upscale building elevator, the Italian rubber flooring in the link below sounds like it would be acceptable.
Just be sure to emphasize that itís not just ordinary common rubber elevator flooring Ö itís Italian.
http://www.thematking.com/business_i...coned-back.htm
DuMass is offline
Old 12-26-2010, 10:32 PM   #4
Fire up the BBQ
griz's Avatar
Rewards Points: 1,746
Look at some of the Altro commercial non slip sheet vinyl flooring. Just an idea.
griz is online now
Old 12-27-2010, 05:55 AM   #5
Doer of Many Things!!!
gideond's Avatar
Trade: Paint and Floor Covering Retailer
Rewards Points: 1,135
We've done a lot of rubber tile but it tends to mark up too easily for these applications. Solid Vinyl Tile is what we usually go for now.
gideond is offline
The Following User Says Thank You to gideond For This Useful Post:
We Fix Houses (12-27-2010)
Old 12-31-2010, 01:17 AM   #6
Herrera Flooring LLC.
Troeskie's Avatar
Trade: Flooring
We have recently started installing Vinyl Plank In the Holiday Inns Here in Texas. Applied with an epoxy adhesive is the good however that all depends on how many elevators they will let you shut down at a time.
Herrera Flooring.
Troeskie is offline
Old 01-01-2011, 10:17 AM   #7
gavinol's Avatar
Trade: home
Before installing your flooring for your elevator cab, you must consider how much the material weighs when you install it. Adding a significant amount of weight to the cab can cause problems to the elevator's leveling abilities.
gavinol is offline
