EasyMat Vs Ditra ?
Old 05-27-2009, 12:08 AM   #1
Suf's Avatar
Trade: Property management
EasyMat Vs Ditra ?
Sq ft price is within 5 cents of each other.
EasyMat is an adhesive backing to the sub floor.
Ditra needs mortar saturated into the felt backing.
Any BTDT experience with the Foam-like roll EasyMat?
I'm concerned with the corners adhesion......and who will back the "Lifetime Warranty"?
Job is a kitchen: 8" joists, 16"o.c and 12' span
50 y.o home w/1x6" original subfloor, w/recently overlaid underlayment 4ply 7/16".........bringing the base floor to ~5/4"
Looking to finish with: 1/4" ceramic 12" tiles.
Transition height to existing hardwood floors (nearly level) is the main issue and the weight upon small joists.
Thanks!
-Suf
Suf is offline
Old 05-27-2009, 12:26 AM   #2
I builds'em
Winchester's Avatar
Trade: Renovations & Decks
Re: EasyMat Vs Ditra ?
If it's only a few cents difference why not go with the schluter? It's proven and they stand behind their product if anything ever does go wrong.
Winchester is offline
Old 05-27-2009, 12:57 AM   #3
"da Whale don't hesitate"
PrecisionFloors's Avatar
Trade: Hard Surface Flooring
Easymat is to Ditra = 5/8" particleboard is to 3/4" T&G Advantech
Precision Flooring
(772) 237-9900
PrecisionFloors is offline
Old 05-27-2009, 12:53 PM   #4
Knowledge Factory
Floordude's Avatar
Uhhh.....
Houston, we have a problem!!!!
http://www.AustinFloorguy.com
Floordude is offline
Old 05-27-2009, 01:04 PM   #5
Originally Posted by Floordude View Post
Uhhh.....
Yep...I missed that. Does not meet L/360 deflection standards, but, I think Schluter will still warranty it with Ditra over single layer plywood/OSB subfloor.....they allow some pretty loose specs iirc. Ditra XL will allow even more.
Precision Flooring
(772) 237-9900
Old 05-27-2009, 01:08 PM   #6
THDTile1229's Avatar
Trade: Tile Apprentice & THD Flooring Associate
Custom Building Products do make some great stuff- but I would add that none of their great stuff is the best in the business...Check with your Local THD - they should have the # to a regional rep for Custom Building Products (That rep provides training to dedicated Tile Aisle associates & also does inspections of jobs in the event you need coverage for their warranties...also keep in mind the job MUST BE LAID to Custom Building Product specs, so if your cutting any corners- you will void out the warranty)- if you can't find an apron (it happens) drop by the tile aisle and flip over a bottle of sealer- take down the 800# on the back...the guys on the other end of the phone can give you any kind of specifics needed on their product- but they'll probably tell you what everyone else here will say and thats to go with the Schluter...
Edit: Keep in mind that most of the associates aren't on the ball- you might want to get in touch with their Flooring Expeditor...that person communicates directly with installers and S/O manufacturers and should have a list of contacts including their Regional Custom Building Products rep
THDTile1229 is offline
Old 05-27-2009, 02:02 PM   #7
Suf's Avatar
Thanks for the info.
In doing further research and your help, we've decided to return the EasyMat and go with the Ditra.
The span is actually around 10'6", So the deflection should be a bit less.
Floor feels solid under my 235lbs. We'll see.
Suf is offline
Old 05-29-2009, 09:55 PM   #8
bathroom guru
jarvis design's Avatar
Glad to hear you took back the easy mat and got ditra
Easy mat just doesn't compare!!
Bathrooms Built for Life.
www.JarvisDesignBuild.com
519-495-4062
jarvis design is offline
Old 07-15-2011, 12:27 AM   #9
Linear Shower Drains
JohnFRWhipple's Avatar
Trade: Linear shower drain installations & waterproofing
What's up with Custom Not allowing Non-Modified Thin-set with Ditra.
Have you guys seen this technical bulletin?
UPDATE;
I just called Custom Building Products and they where stumped over this bulletin. I was told this morning that they do recommend Non-Modified thin-set and even make an uncoupling thin-set which is non-modified.
Custom Building Products can be reached at;
Corporate Headquarters
13001 Seal Beach Blvd
Seal Beach, CA 90740
562-598-8808
Customer Support
Ph 800-272-8786
Fax 800-200-7765
John Whipple (By Any Design Ltd.) - Member of Terrazzo Tile and Marble Association of Canada, the National Kitchen & Bath Association and the National Tile Contractors Association. Specializing in Vancouver bathroom renovations, linear shower drain installations and shower waterproofing procedures.
JohnFRWhipple is offline
Old 07-17-2011, 06:24 PM   #10
Sam
astor's Avatar
Trade: Wood Cork and Leather Flooring and more
I am not sure what the EasyMat is but I have been using Protecto Wrap Whisper Mat over concrete floors and have great results.It is much cheaper than Ditra and less labor intensive. I am planning to use same for upcoming project over plywood subfloor which has passed deflection test by structural engineer.
Featuring Click Leather Floors
http://www.designershardwood.com
astor is offline
Old 07-17-2011, 08:45 PM   #11
Alone Eagle Remodeling
Tech Dawg's Avatar
Trade: Tile and Stone Showers & Floors
Strange article... Dal here has Easy Mat (the thinset down version). I may try it out sometime but right now I'm liking the Noble TS the most.
Eventually I have another bathroom floor to retile so I thought about tryin the Easy Mat in there. Has anyone here actually used it??
Todd
Perfect work just isn't free
www.aloneeagle.com
Tech Dawg is offline
Old 07-29-2011, 07:20 AM   #12
opiethetileman's Avatar
Trade: DIYer apparently
wasnt there easy board or something like that as well??? kinda the first trial of kerido board??? Anyway the Bedrosains here in jax has 2 pallets of stuff throwing it out
opiethetileman is offline
Old 08-11-2011, 10:10 PM   #13
CO762's Avatar
Trade: Remodel
I have (primer one) and it wasn't bad to use. The hardest part was unrolling it and getting it flat. Corners I had to weigh down and marking it sucked. Never had to take off any done, so I don't know how well it sticks. I've always been impressed with laticrete's 150's bonding though. If it sticks like that, it's good.
CO762 is offline
Ditra Failures?? jarvis design Ceramic & Stone Tile 45 01-21-2011 08:14 PM
I like my Ditra flat dammit! orson Ceramic & Stone Tile 6 02-24-2009 05:11 PM
Ditra for mesh backed pre-cut flagstone/any good? jciotti7 Ceramic & Stone Tile 5 02-12-2009 05:26 PM
rapid set with Ditra tang Ceramic & Stone Tile 4 01-06-2009 09:26 PM
Dricore and Ditra matting MAD Renovations Flooring 3 11-30-2008 01:06 PM
