Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Flooring
Old 01-11-2005, 01:35 PM   #1
Trade:
Question Dupont Laminate Flooring
I'm looking to install laminate floors in my basement. The floor is cement. I went to HD yesterday and they sell Pergo, Shaw and Dupont. HD is having a 20% off all laminate floors until 1/19.
Dupont is the most expensive, but they have a padding attached to the back of each board which according to the Dupont call center eliminates the need for addtional padding. A vapor barrier is still needed.
Has anyone used or heard anything about Dupont laminate floors?
I've read on this forum that I should apply 2 coats of concrete sealer after I have totally cleaned the concrete.
Should I place additional padding anyway?
Any other tips?
Anyone know of an installer on Long Island, NY?
artie is offline   Reply With Quote
Old 01-11-2005, 04:48 PM   #2
Don Benham's Avatar
Trade:
Send a message via AIM to Don Benham
I prefer on-attached cusions with laminates. I'm not positive about Dupont's but usually you get an inferior pad when it's included. I prefer a heavier padding. Cork and rubberized make good underlayment materials for floating floors. Quieter and longer-lasting.
Don
Benham Flooring
__________________________________________
Look, I know the voices in my head aren't real, it's just that lately they've had some really good points.
Don Benham is offline   Reply With Quote
Old 01-11-2005, 09:39 PM   #3
Teetorbilt's Avatar
I have installed some DuPont but not much, given the name I would expect a good product.
I'm the one that expounds on sealing the concrete. I live in So. FL where you can't dig a hole 3 ft. deep without hitting water. Most of the state is only a few feet above sealevel and we get over 50 ins. of rain a year. Last Sept. we got 40+ ins. in a month. This is why I advocate sealing slabs here. Your situation may be different.
As to underlay/vapor barrior, I like Armstrong's 2 in 1 when used flooring with the underlay attached. The 1/4" stuff is a bit much.
Teetorbilt is offline   Reply With Quote
Old 01-12-2005, 03:11 PM   #4
Trade:
Thank you for all your help and advice. I really appreciat it. I'll let you know how it goes.
Old 11-14-2005, 01:50 PM   #5
Trade:
Two underlayments
Can you put an underlayment down in addition to the pre attached stuff? I thought Dupont told me not too. I would like the added cushion.
zbwmy is offline   Reply With Quote
Old 11-14-2005, 05:46 PM   #6
Flooring Guru
Floorwizard's Avatar
Trade: Sales Manager
Do not add an additional padding, that is the reason I do not like the attached pad. You cannot upgrade pad.
Use a 6 mil poly first for moisture.
Dupont has better grade than the one you bought at home depot, but, the quality is still good.
Floorwizard is offline   Reply With Quote
Old 11-19-2005, 05:12 PM   #7
General Contractor
nadonailer's Avatar
I installed one of these recently and was told additional underlayment was not needed. I suppose you could add it though.
nadonailer is offline   Reply With Quote
Old 11-19-2005, 11:05 PM   #8
Teetorbilt's Avatar
I do it all of the time. What is the argument?
Albert Einstein
Old 11-19-2005, 11:57 PM   #9
Flooring Guru
what is the argument for installing additional pad?
well, it could be too soft and add stress on the joints.
Air Bubbles in Laminate Flooring Bigman Flooring 19 09-05-2007 09:07 PM
Removing a small section of laminate flooring MKamis Flooring 3 07-30-2007 05:02 PM
Laminate Wood Flooring Over An Old Garage Floor mjm0073 Flooring 1 01-30-2007 10:42 PM
Miter Joints In Laminate Flooring ?? AL MURZYN Flooring 6 12-27-2006 10:15 PM
Laminate Flooring pricing mpohl77 Flooring 3 02-18-2006 11:04 PM
