Dry Grout On Tiles.
OK this will sound like a HO question, guess it kinda is? Anyway, couple of months ago I set the ceramic tiles in a friends bathroom. He said he would take care of the grouting. Well, he grouted while he was enjoying a few Rums (little Jamaican guy) and he ended up passing out before he completely cleaned the grout off the tile.
![]() What will take the dried grout off the tile? What method would you suggest? |
Trade: Construction
Re: Dry Grout On Tiles.
Elbow grease and some more rum.
#3 | |
You did what??
Re: Dry Grout On Tiles.Quote:
so, ya feeling a little guilty about this "friend" and feel you owe him?
Hahaha. Well the Rum, it's good but 180 proof Jamacain Rum doesn't help me any.
Was thinking a 3M scouring pad on an angle grinder? Don't want to take the finish off the tile.
Trade: Repair and remodeling
vinegar
Trade: Construction
Re: Dry Grout On Tiles. |
Its all ball bearings
Trade: Tile
x2 for vinegar and microfiber....
Angus L+M+O+P=C ![]() "Promise only what you can deliver. Then deliver more than you promise" |
The Remodeler
Trade: Home Remodeler
vinegar and a scotch brite by hand... no angle grinder....
If that doesnt cut it, you can get sulfamic acid crystals at the local HD.. (In the tile aisle) mix with water and wear some gloves... |
Speedy clean.
It ain't Rocket Science unless you are building rockets. |
Trade: Flooring, Tile & Stone
You can go the acid route we've done that plenty of times but be real careful with anything metal in the room such as plumbing fixtures etc. The acid is not so forgiving on metal.
The Old Master
Trade: Plumbing & Heating
We used to find this quite often. Not tile groute but dried spackel compound on fiberglass plumbing showers & tubs.
These don't take to much scraping, acids, sanding and whatnot. What I found worked the best was a sharpened stick. Picture a paint stirer 1/4 x 1" with a 45 on the end. I used to make them out of oak. The oak did not scratch the fiberglass but it sure loosened up the spackel globs. Should work on smooth tile. Last edited by Plumber_Bill; 09-05-2009 at 05:32 PM. Reason: added word smooth |
#12 | |
Trade: Tile
The Remodeler
The sulfamic acid is very mild...Comes in powder form, easy to mix. Muriatic is the truly dangerous stuff... Comes in liquid form, always add acid to water, never water to acid.... Less likely to splash the concentrate on yourself that way... Muriatic fumes will corrode plumbing fixtures, very unlikely with Sulfamic...
There's truly never a reason a tile guy should be using Muriatic Acid anyway.... |
| Grout Sealer changes color of grout | onlinehandyman | Flooring | 6 | 01-15-2010 09:00 PM |
| Cultured Stone grout question | HigherLivingLLC | Masonry | 13 | 09-14-2009 08:34 PM |
| Saltillo tile grout info? | Dklein | Flooring | 12 | 05-26-2009 03:33 PM |
| Grout Width and sealing. | jritkes | Flooring | 6 | 09-28-2008 08:23 PM |
| cleaning grout from terracotor tiles | roo | Flooring | 4 | 06-27-2008 12:53 AM |
