Originally Posted by Florcraft
Google (insert floor here) bad experience and you will find tons on all products.
Careful what you read.
Good luck
I couldn't agree more. You never know how they really installed the stuff.
It looks like a common theme in the bad experiences with the TrafficMaster/Allure product, is not keeping the room warm enough. The instructions say the room needs to be something like 65-85F or the glue won't setup properly. Also you need to be sure to roll it after. I see similar complaints about Konecto. All were over concrete.
So like I said, this is in New England, and this basement slab is definitely colder than 65F... I doubt I could even heat it up that much. I'm thinking its probably a good idea to stay away from this product in this situation and go with a wood laminate. Do you guys agree? Or has someone here used this product in a cold climate over concrete without problems?
Thanks again
Charlie
